Pages: 1 [2] 3 4 5 6   Go Down
Author Topic: Need Sum Help ASAP Please  (Read 12733 times)
Re: Need Sum Help ASAP Please
« Reply #15 on: 27 November 2009, 16:38:16 »
Just sounds like a possible flat battery
ryan2.2
  • Chadderton Manchester
« Reply #16 on: 27 November 2009, 16:42:40 »
I see I can bump start it tho could it still be a flat bat?? dont know much bout cars
« Reply #17 on: 27 November 2009, 16:45:43 »
Yep, enough juice to run the electrics but not enough to crank the engine....could also be a knackered battery to
ryan2.2
« Reply #18 on: 27 November 2009, 16:46:52 »
Would that make the orange light come on?
« Reply #19 on: 27 November 2009, 16:48:14 »
It could do, low battery voltage warning code
ryan2.2
« Reply #20 on: 27 November 2009, 16:50:18 »
will try that
ryan2.2
« Reply #21 on: 27 November 2009, 21:02:13 »
Just thought I would give you all a bit of a up date tryed the pedal trick it worked whoo it gave mw a code of 10 3 4 10 does any 1 know what it means???
ryan2.2
« Reply #22 on: 27 November 2009, 21:03:39 »
  • Auckland
    • Mazda MPV
« Reply #23 on: 27 November 2009, 21:14:25 »
There is a guide to the error codes in the maintenance section (index here http://www.omegaowners.com/forum/YaBB.pl?num=1259003779)
http://www.omegaowners.com/forum/YaBB.pl?num=1197277611
says 0340 is camshaft position sensor.
Quite common on the 2.2 apparently.
ryan2.2
« Reply #24 on: 27 November 2009, 21:17:27 »
Great new..... sorry to be thick but what does it mean ??
KillerWatt
« Reply #25 on: 27 November 2009, 21:18:32 »
That wouldn't cause the starter to fail to operate in it's entirety.
@ the OP
Does the EML lamp extinguish within 5 seconds of the car starting once you have successfully bumped it?
ryan2.2
« Reply #26 on: 27 November 2009, 21:21:24 »
sorry what is the EML lamp is that the orange light if so no it stayed on after i bumped it
  • Auckland
    • Mazda MPV
« Reply #27 on: 27 November 2009, 21:34:03 »
Camshaft sensor problem does make the car difficult to start so putting extra load on the battery.
Not saying the battery or charging system is beyond doubt but you don't have to crank a non starting engine for long to discharge the battery to the stage where it won't turn over at all.
« Reply #28 on: 27 November 2009, 21:36:24 »
Usually its hot start issues only with cam sensor on 4pot, cold starts won't be an issue.
ryan2.2
« Reply #29 on: 27 November 2009, 21:38:36 »
Since last night when the car would not start its not turn over all i get when i turn the key is lights on the dash board so i will try the battery idea in the morning sum jump lead off a diffant car if that does not start the car will have to pick your minds sum more thanx guys
Pages: 1 [2] 3 4 5 6   Go Up
