Author Topic: V6 DIS Query  (Read 2391 times)
Re: V6 DIS Query
« Reply #15 on: 06 December 2009, 23:04:36 »
Given proper maintenance, they rarely fail.
maintenance on a coil? Remove it a polish it each week?  :-?  :-?
Yes Andy... if thats what you want to do.
Me? i'd be making sure the scuttle is doing its job and not pouring water onto the DIS & plugs.
But if you want to get out the polish be my guest.
That's what mine's been doing  :y
Yup, thats why i mentioned maintenance. As always Andy starts with the patroinising sarcastic posts and use of  ":-?"
 :-?  :-?  :-? Sarcastic? Moi?  :-? ::) ::)
Yup, you need to remove that chip on your shoulder  :y  :)
Re: V6 DIS Query
« Reply #16 on: 06 December 2009, 23:08:47 »
 :-X :-X :-X :-X  I find it mildly ammusing being 'shouted at' by someone who is barely older than my own lad ....... you do share the same attributes though. He thinks he knows everything there is to know about everything too!!!! ;) ;) ;)
Re: V6 DIS Query
« Reply #17 on: 06 December 2009, 23:12:32 »
Can't see where i used capitals on this thread  :-/
Also my comments are valid, which you have ignored.
Re: V6 DIS Query
« Reply #18 on: 06 December 2009, 23:18:38 »
http://www.omegaowners.com/forum/YaBB.pl?num=1259838972  ::)
« Last Edit: 06 December 2009, 23:19:20 by tunnie »
GPar
  • Chatham, Kent
Re: V6 DIS Query
« Reply #19 on: 07 December 2009, 01:24:43 »
Blimey, this is getting as bad as my fishing forum! For what it's worth, I've had two Bosch dispacks fail on a car that has done 130k. The last one only did 45k. Both looked fine externally. I've put a cheapo pattern one on this time although to me it looks identical in every way externally to the Bosch one, just no numbers. Only done about 500 miles and it seems fine, guess time will tell.
Geoff
« Last Edit: 07 December 2009, 01:26:29 by GPar »
Re: V6 DIS Query
« Reply #20 on: 07 December 2009, 08:40:43 »
I changed a dis yesterday that was in a bad way. The car was mis-firing and a new dis pack solved the problem. I have seen a few faulty dis packs.
Re: V6 DIS Query
« Reply #21 on: 07 December 2009, 09:45:14 »
I think I would have to consider if 1, I could afford a Bosch one and 2, am I keeping the car. If the answer is yes then I would buy Bosch.
