Author Topic: Another key fob question  (Read 3467 times)
Ken L
  • Sheffield, South Yorkshire
Re: Another key fob question
« Reply #15 on: 12 December 2009, 21:51:00 »
I did a further check today and my car does have a factory fitted alarm, I was looking in the wrong place for the interior sensors, they're on the middle pillar not front pillar, ( as you guys will already know), unlocking the car with the key turns off the alarm same as the remote does, all works fine including total closure.
  So the red light key may work after all, I need to follow advice given and check the circuit boards in the keys.
« Reply #16 on: 12 December 2009, 21:59:26 »
Have you got a switch with a little man running away from ))) ? This turns off the interior sonics fro m te alarm, so if the answer is yes, then it confirms you have alarm.  :y  :y
My 99 miniface lift has an led on the key. I've just got a facelift diseasal & its key does not appear to have an led ..... it still works as it should though, so who cares?  ;D  ;D
Ken L
« Reply #17 on: 12 December 2009, 22:11:55 »
Yes Andy it does have that switch, I know it's got an alarm, I locked the car with the window open, waited a while then waived my arm inside the car and the alarm went of  :y
 I want to make sure the second key is compatible as it will have to be programmed to the car, otherwise the fob is useless
« Reply #18 on: 12 December 2009, 22:14:08 »
I've gone the easy but more expensive route for a second key & spoken to Dr O in Ellesmere Port .......
but he won't come on here!!!!!  :-?  :-?  ;D  ;D  ;D
Martin_1962
« Reply #19 on: 12 December 2009, 22:38:46 »
Is the fob broken inside then?
« Reply #20 on: 12 December 2009, 22:40:38 »
Me?
I think you fixed the gubins inside it!  :y :y
Page created in 0.027 seconds with 16 queries.
