Author Topic: Windscreen Seal  (Read 2337 times)
Windscreen Seal
« on: 16 December 2009, 15:48:45 »
The windscreen seal on my 2.5 V6 has come loose at the bottom. As a result, the padding in the scuttle is filling up with water like a sponge, and this has been dripping onto the DIS and killed it.
Obviously I will need to dry the scuttle out - but can anyone advise on methods of getting the windscreen seal stuck back down in place?  :y
cruisetopoland
  • UK
Re: Windscreen Seal
« Reply #1 on: 16 December 2009, 15:54:25 »
I find this is a job best left to a decent windscreen fitter-drop into one of the windscreen chain places and ask meekly for help.
They usually won't take any money, or will be chuffed with a fiver-cheaper than buying the sealant.
Hope this helps  :y
Re: Windscreen Seal
« Reply #2 on: 16 December 2009, 16:19:02 »
auto glass via insurance. But then i needed a new screen anyway. ;)
Re: Windscreen Seal
« Reply #3 on: 16 December 2009, 16:20:47 »
nail + hammer + a little force + call to autoglass (make sure your fully comp)
« Last Edit: 16 December 2009, 16:21:09 by tunnie »
Re: Windscreen Seal
« Reply #4 on: 16 December 2009, 16:37:44 »
Without wanting to sound holier-than-thou.. insurance fraud (which is that that amounts to) isn't an option, for me  :y
cruisetopoland
  • UK
Re: Windscreen Seal
« Reply #5 on: 16 December 2009, 17:23:39 »
Hence the go to the windscreen guys and ask for help response  :y
I had a (non-Omega) screen taken out and put in for £25 a few years back, but you will probably get away with a re-seal for a fiver or so  :y
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Windscreen Seal
« Reply #6 on: 16 December 2009, 23:07:46 »
seeek and seal (Windscreen repair)should fix it, have to put some masking tape over it and leve for an hour, then use some white spirit to clean off the exsess, it not cheap but it better than having window out and new one fitted. £10 a can.
« Last Edit: 16 December 2009, 23:24:58 by Russell_Hill »
Re: Windscreen Seal
« Reply #7 on: 16 December 2009, 23:17:50 »
James james james. I didnt say anything about damaging the screen. Just visit auto glass and discuss your options, they can be very helpfull. Ime it will come down to weather you want to pay £70 excess for a screen or bung em a couple of quid for some goo. Costs nothing to talk, nor is that illegal. Last I heard anyway. :-)
Re: Windscreen Seal
« Reply #8 on: 16 December 2009, 23:24:21 »
My reply wasn't aimed at you, mate...... moreso the "hammer, nail, insurance" post...  ;D :y
Re: Windscreen Seal
« Reply #9 on: 16 December 2009, 23:31:29 »
I could do to find my  ::)  ::)  ::) :y
« Last Edit: 16 December 2009, 23:31:55 by Andy_B »
Re: Windscreen Seal
« Reply #10 on: 16 December 2009, 23:32:25 »
Heh.... a tube of gripfill will be much less risky  ;D
Re: Windscreen Seal
« Reply #11 on: 17 December 2009, 08:19:20 »
The actual windscreen seal will have no effect on water getting on the DIS.
The rubber snap in trim (which is not part of the seal) might but, I am not personaly convinced as this does little more than reduce wind noise.
The usual culprit is the section where the scuttle cover sits on the scuttle metal work.
Re: Windscreen Seal
« Reply #12 on: 17 December 2009, 09:57:13 »
Sorry, I should have been clearer - I think it's this trim, that runs along the bottom of the screen, that is the culprit...
Re: Windscreen Seal
« Reply #13 on: 17 December 2009, 10:05:39 »
You mean the rubber on the edge of the scuttle panel that rests against the outside of the windscreen?
First thought in that case is: are all the little clips in place underneath it?
Sealing that using sealant will be a pain because the scuttle panel needs to be removable.
If the rubber strip is knackered try the stealers for a new rubber strip or just buy a scuttle panel from a breaker.
Re: Windscreen Seal
« Reply #14 on: 17 December 2009, 10:06:56 »
Actually, I'm being a numpty. The scuttle panel fits under this seal, doesn't it?
Is water leaking into the car or just behind the scuttle?
