Author Topic: Heated seat  (Read 2578 times)
mathewst
  • Split, Croatia
    • v40
Re: Heated seat
« Reply #15 on: 23 December 2009, 14:29:00 »
Looks like I have the same problem.
When the drivers side is on setting 1 my arse starts to feel like sitting inside the oven. And only the bottom part of the seat is heated. Upper part stays cold :-?
Passengers side works ok
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
Re: Heated seat
« Reply #16 on: 23 December 2009, 15:38:25 »
Driver's side seat heater runs on full power even when "1" selected.
Any ideas where to start looking? (In order of "easiest to check" first please! :))
I had this problem just before the elements burnt out. On setting 1 in was red hot, too hot in fact and just after that an awful smell of burning (could have been my arse  ;D) and then no more heated drivers seat. :'( Being leather I can't replace elements either.
Re: Heated seat
« Reply #17 on: 23 December 2009, 17:40:44 »
Cant remember if they are shaped on facelifts, but is it poss to swap the passenger/drivers switches over to test.
GaryBC
  • Egham, Surrey
Re: Heated seat
« Reply #18 on: 24 December 2009, 10:14:54 »
Ok. Here's another question. If I disconnect the seat heater element connector, then select 1 - 5 in sequence, what voltages should I expect to find on what pins? (PS, where's the connector?!)
'Coz if the control circuitry has failed I will rig up some sort of inline controller - rather than go pulling dash panels down! (But I need to know what it has to do first.)
mathewst
  • Split, Croatia
    • v40
Re: Heated seat
« Reply #19 on: 24 December 2009, 10:28:07 »
Yes they are shaped TheBoy on facelifts. Right and left vare different
