Author Topic: Door check strap/bar help please.  (Read 4722 times)
hotel21
  • The Kingdom of Fife
Re: Door check strap/bar help please.
« Reply #15 on: 26 December 2009, 17:24:25 »
The edge of the door through which the pictured mechanism passes is simply a pressed plate, constructed as part of the door at the factory.
Replacement/repair is by means of the guide as shown, whereby a 2 part repair plate is used, sandwiched either side of the remains of the original door.
The mechanism may be in the door where a previous owner ha dumped it, ir in the boot or in the skip.
Its the same mechanism for either side, the arm is marked L and R so that its the correct way up for either door.
HtH   :y
Ken L
  • Sheffield, South Yorkshire
« Reply #16 on: 26 December 2009, 17:24:58 »
Yes, Welung, that plate with the rectangular hole for the bar strap to go through, with the bolt holes....all that is gone!
« Reply #17 on: 26 December 2009, 17:25:00 »
The part of the door skin that the strap was bolted to is either at the bottom of the door, or still bolted to the strap at the bottom of the door. The repair mentioned in the 2 links above just sandwiches either side of the remnants of the front edge of the door.
If you wanted to go the whole hog & do the repair that Vauxhall would've done if you'd qualified at the time, then you can drill the spot welds out & replace this bit ......
« Last Edit: 26 December 2009, 17:26:24 by Andy_B »
Welung666
« Reply #18 on: 26 December 2009, 17:26:11 »
As Broocie says, you need the repair kit from Vx and a replacement mechanism :y
Ken L
« Reply #19 on: 26 December 2009, 17:32:57 »
Ha Ha! AndyB, after reading that with no spaces, then going to the pic...that is what is missing!, so can I buy that from the dealers, and drill and bolt it into place? is the original one welded in place at the factory did you say ( can't read it again to check)
hotel21
« Reply #20 on: 26 December 2009, 17:33:15 »
Or remove the door and weld in a repair panel then refinish.  As AndyB says, its how the original recalls were done, albeit with a factory supplied, shaped, repair panel.  Now, its probably as easy with a workshop offcut....
Once its all back into place, its not really visible, unless someone peers through the closed door gap with the wing, using a torch...  ;)
Ken L
« Reply #21 on: 26 December 2009, 17:35:02 »
Ah! it's back readable and with pic....thanks.
« Reply #22 on: 26 December 2009, 17:39:21 »
I can drag & drop much better with a proper mouse than I can with a lap top touch pad .....  ;D  ;D
Ken L
« Reply #23 on: 26 December 2009, 17:40:40 »
Thanks for all the help guys, I think I know what I want now.
I'll get the part from the dealer if I can, otherwise make one, and drill and bolt into place.
  I'll see if the mechanism is still inside the door, if not I will be needing that.
Thanks again ...very much apreciated
« Reply #24 on: 26 December 2009, 17:52:02 »
You'll need to provide the dealer with the part numbers. As Vauxhall didn't admit to having any problems, it means the part numbers aren't that easy to find.  :y  :y  :y  :y
Ken L
« Reply #25 on: 26 December 2009, 17:56:04 »
Is that the part number on the plate in the pic? Can't quite make it out properly, any idea what it is?
« Reply #26 on: 26 December 2009, 18:02:08 »
Don't change that bit, it's way over the top. Mine was 'fixed' using the plates shown in the how to link ie
4 x 9195961 (reinforcement plate) @ £1.04 each. You need to trim to length the two outer plates to fit into the 'hole' at the front edge of the door, and then bolt the othe plates inside the door. It depends how much metal you have left as to how good a repair you end up with. You'll still end up with a reasonable/servicable 'repair'  :y  :y  :y
Ken L
« Reply #27 on: 26 December 2009, 18:16:41 »
That how to is if the internal bracket/plate is still there, as it's all on the inside, inside the door hole, as stated I just have a gaping hole in the door the plate in your last pic has broken away inside, Those small black plates with the square slot and bolt holes would have nothing to bolt to.
« Reply #28 on: 26 December 2009, 18:22:36 »
Your door is like my drivers door is. When you use 2 plates on each door, you're just sandwiching what's left between the plates. You use a nut & bolt through each hole of the plate, whereas when new the nut would have been captive (I think  :-/) on what is now in the bottom of your door. The best thing is to catch the problem early, so that there is still metal atthe front edge of the door.  :y  :y  :y
« Last Edit: 26 December 2009, 18:24:13 by Andy_B »
Ken L
« Reply #29 on: 26 December 2009, 18:37:53 »
I see the point, but on mine there is nothing left to sandwich between the new plates.
I might just make a plate to fit inside the door and drill and bolt it into place if I can't get the part from the dealer.
