Pages: 1 2 [3]  All   Go Down
Author Topic: Automatic gear lever lights  (Read 4255 times)
trinity0_10
  • Norfolk
Re: Automatic gear lever lights
« Reply #30 on: 29 December 2009, 11:09:21 »
Hi Dan, There should be no reason to release the heat shield. I used a 1/4" drive with a long reach socket to undo mine, you do have to search with your fingers to find the bolt or use a mirror & torch to see what you are looking at. I found it had to be a 1/4" drive though as other size drives seem too big. Quicker than a bit of turn with a spanner as once the bolt is loose just use the socket between your fingers to spin the bolt out.
Try the mirror & torch to locate the bolt first though.
Mike
Omega Elite 1999 2.5 saloon LPG
Vectra SRi 1998 2.0 Estate LPG
Dan Hope
« Reply #31 on: 29 December 2009, 11:13:09 »
hi there,
ive found the bolt, i just cant seem to get any purchase on it whatsoever with any weapon i can find.
what im more scared of now is that at the moment the car drives, once i get this thing off i don't think i'll be able to get it back on n then im proper screwed for a car.
im not confident with this kinda thing at the best of times n am willing to pay someone to help me, but i know the likes of vauxhall will rip me off n tell me i need a whole new switch etc
trinity0_10
  • Norfolk
« Reply #32 on: 29 December 2009, 11:42:34 »
If you haven't a 1/4" drive & can get another socket on the bolt which protrudes a bit you can also use mole grips to get it started.  If you are not confident then help is the best idea, I removed , cleaned , checked contacts were working with a meter & replaced it in under an hour [ although mine wasn't the problem, still using it as a manual  :-[ ]
Mike
Dan Hope
« Reply #33 on: 29 December 2009, 16:37:38 »
It's FIXED!!! Guffer (Matt) thanks so much, i'm so pleased!!you've really taken the pressure off  :) just let me know if there's anything I can do for you  :y
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #34 on: 29 December 2009, 16:48:30 »
No worries mate, it was a nice learning experience for me and that spare box in my garage helped with guessing the location of that hard to reach bolt.
FYI those with facelifts it would seem that the access is made more difficult through various heatshields and the like which are not present on my prefacelift. I used 10mm sockets of varying lengths to get at the bolt because of them.
Dan here is a website about the thing I was telling you:
http://www.payitforwardmovement.org/
The theory is that favours you pay forward come back through strangers at the most unlikely (and most needy) moments.  It's a little bit hippy karma-tastic but I beleive in it :y
Dan Hope
« Reply #35 on: 29 December 2009, 16:52:44 »
cool, well it worked for me so i'll certainly give it a look once ive thawed out properly ;)
davethediver
  • Blackburn, Lancs.
« Reply #36 on: 29 December 2009, 17:12:22 »
Nice to hear you got sorted Dan thats what OOF's all about and well done guffer for helping out a member in need. :y :y
P.A. Caron de Beaumarchais
Pages: 1 2 [3]  All   Go Up
