Author Topic: Lambda sensor location  (Read 1514 times)
dopey
« on: 29 December 2009, 11:05:55 »
Guys
My car has died over night (yet again).
Same issue as before, engine turns over, runs for a few seconds then just gets rougher and rougher until stalling.
Checked the fault codes and its stating that its the fuel trim.
Recently had a garage replace the crank sensor and coil packs.  They also said that the lambda sensor wires were loose, and reconnected them.
Wanted to just check they hadn't come loose again, so at the risk of sounding daft, where is the lambda sensor and the connecting plug located?
Cheers
Re: Lambda sensor location
« Reply #1 on: 29 December 2009, 13:37:55 »
4 lamdas on your car.
Before 'guessing' the problem, and potentially adding new faults, do a 'Pedal Trick' (search the Maintenence Guides for how to do this) to see if any codes stored :)
dopey
« Reply #2 on: 29 December 2009, 15:53:34 »
aye - i got 170 and 173 which both appear to be fuel trim errors on a 2.6 V6.
4 sensors!!!
Thats it, i'm just going to use my bike instead, don't think it knows what sensors are (other than oil pressure), though boot space is limited.
« Last Edit: 29 December 2009, 15:55:46 by dopey »
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« Reply #3 on: 29 December 2009, 15:56:00 »
I was getting the P0170 code for fuel trim on my 2.2 .... turned out it was the Maf sensor  :-/
dopey
« Reply #4 on: 29 December 2009, 16:19:08 »
MAF was going to be next on the list.  Was just wanting to check Lambda sensor as have been informed by garage  that one has a loose connection (wishful thinking probably).
This car seems to be a friday afternoon car!! >:(
Not sure whether it helps or not, but the car was running fine (at least for the last month), then I left the road side lights on for a few nights in v v cold weather, which flattened the battery.  Charged battery back up and car was rough as a badgers arse again.
Is a temporarily flattened battery likely to bugger anything else up, or is it likely to be a conicidence?
« Last Edit: 29 December 2009, 16:26:57 by dopey »
« Reply #5 on: 29 December 2009, 17:19:00 »
I wonder if the garage have "crossed" the lamda's ?? if they have the poor ECU is going to be going nuts trying to trim the "wrong" bank .. every action will get worse not better .....  :(
Just a thought ???
unlucky mark mv6
  • tipton,west mids
« Reply #6 on: 29 December 2009, 17:38:44 »
Just a thought ???
Me personally wouldent trust any garage with my car. :-/
dopey
« Reply #7 on: 29 December 2009, 18:12:27 »
so where abouts are the sensors and connections?
« Reply #8 on: 29 December 2009, 19:38:48 »
Disconnect MAF sensor - if it starts ok and revs thats your problem!!
« Reply #9 on: 29 December 2009, 20:41:14 »
On each bank, there is one before and one after the precat (which is before the main cat)
dopey
« Reply #10 on: 29 December 2009, 20:57:51 »
Cheers for that.
Are they fairly easy to access or is it a 'drop lots of things off' type excercise?
dopey
« Reply #11 on: 30 December 2009, 10:55:44 »
dbug - your a genius!
Unplugged MAF, car worked.
Plugged back in - knackered.
Unplugged again - works perfectly!!
Just off to get a new one now.
Cheers again guys. :y
