Author Topic: Bad brakes  (Read 5091 times)
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
Bad brakes
« on: 27 December 2009, 12:27:13 »
Hello
I drive 2001 sedan with Y26SE. Brakes are really bad. All pads are new and all pistons and other moving parts move well. I once read in this forum that Omeaga brakes should work so that when you "Jump on Pedal the whole world stops". Mine does not work like that. In normal driving/braking all is OK but when brakes are really needed they are uneffective. To be honest have to admit that I never changed the brake fluid but I do not believe that it is the reason - the pedal "touch" is good - I mean it is not soft. Does anyone of you have same kind of problems ?
Re: Bad brakes
« Reply #1 on: 27 December 2009, 12:30:12 »
Hello
Brake Fluid lasts 2 years, once its been used in anger it can boil, and then its had it really....
I flushed my brake fluid 2 years ago, past few weeks i have really noticed a drop off in performance.
I'll be changing it shortly, also do a propper flush and not just top up the tank. If its old i also pinch the last stuff out of the caliper as thats what causes the problems. Put some mole grips on the feed pipe, then push the caliper in, and that should really squeeze the last of the bad fluid out.
Make sure you close the bleed nipple in time, to stop it sucking in air
« Last Edit: 27 December 2009, 12:31:36 by tunnie »
polilara
  • Finland
Re: Bad brakes
« Reply #2 on: 27 December 2009, 12:54:00 »
Hello tunnie
Thanks for comments. I'll change the fluid tomorrow and try to flush also the calipers as you advised. Come back then with news.
Re: Bad brakes
« Reply #3 on: 27 December 2009, 12:55:52 »
Handy guide here:
http://www.omegaowners.com/forum/YaBB.pl?num=1156881883
Only attempt it if your confident with car DIY  :y
Markjay
  • London
Re: Bad brakes
« Reply #4 on: 27 December 2009, 13:14:29 »
Brake fluid, as tunnie says... Omega brakes are generally very good.
« Last Edit: 27 December 2009, 13:14:54 by markjay »
Alas, no more Omegas....
Re: Bad brakes
« Reply #5 on: 27 December 2009, 14:01:25 »
I never managed to get good 'bite' from pattern parts, so went back to genuine pads and discs
JasonH
Re: Bad brakes
« Reply #6 on: 27 December 2009, 16:17:31 »
I've always found the Omega brakes adequate (that's with genuine pads and disks and fresh fluid). They stop a fully loaded Omega estate and caravan just fine. Having said that other make cars (Honda, BMW) I have driven had had "sharper" brakes with more assistance.
sexydaz
Re: Bad brakes
« Reply #7 on: 27 December 2009, 17:04:46 »
ive always found if the brakes on yer van are set and working correctly you stop better,ive had cars that felt better while towing
Tony H
  • liverpool
  • Black Elites are luurvley
Re: Bad brakes
« Reply #8 on: 27 December 2009, 19:42:55 »
Obviously the fluid could do with a change. If the brake pedal feels springy this will probably down to the new pads you have fitted have not bedded in yet, this will also have a negative effect on braking performance
« Last Edit: 27 December 2009, 19:44:59 by Tony_H »
Re: Bad brakes
« Reply #9 on: 27 December 2009, 20:49:42 »
Check the brake servo pipe for damage and air leaks
polilara
  • Finland
Re: Bad brakes
« Reply #10 on: 28 December 2009, 09:36:55 »
Thanks for all comments.
I changed the pads last spring - manufactured by Jurid. Have to buy next time genuine ones. The reason for change was uneffective brakes. At the same time I checked that all moving parts are really moving well. Nothing changed in brake efficiency and now after 5000 km drive I believe that pads found their place - pedal is really not springy. Servo pipe is checked. Vacuum remains and servo works. I once checked by switching off the engine. After a couple of brakings the brakes became really bad.
I repeat that someone in this forum once said that "when you jump on pedal the whole world stops". I supposed that there is some kind of "brain" in braking control system which recognize the panic braking and increase the assistance. Is there that kind of control unit ? If there is that could be broken. As said I'll change the fluid today and come back.
davethediver
  • Blackburn, Lancs.
Re: Bad brakes
« Reply #11 on: 28 December 2009, 12:40:43 »
Jurid pads are what the omega left the factory with IIRC :y
P.A. Caron de Beaumarchais
Re: Bad brakes
« Reply #12 on: 28 December 2009, 12:53:44 »
I supposed that there is some kind of "brain" in braking control system which recognize the panic braking and increase the assistance. Is there that kind of control unit ? If there is that could be broken. .....
No variation of Emergency Brake Asssit on an Omega.  ;)
polilara
  • Finland
Re: Bad brakes
« Reply #13 on: 29 December 2009, 20:09:50 »
Finally got the fluid changed, also calipers flushed. That match snow in Finland that even my brakes activated the ABS. Can test them better later. However, I believe that nothing really changed.
What I realized is that when the car was parked and I was pressing the pedal strongly (engine running) the pedal was slowly going to the floor. So I suppose I have a problem in my main cylinder or main caliper - I do not know the English word. That could explain that when I really jump on pedal I never get good 'bite'. As I never loosed brake fluid during last years I think that I need a repair kit for the main brake cylinder.
Is that available ?
Another question: Can anyone of you block your brakes or activate your ABS when driving in summer in dry asphalt road ? I never succeeded even though when using two feet. Perhaps I am too weak ??
Tony H
  • liverpool
Re: Bad brakes
« Reply #14 on: 29 December 2009, 22:08:38 »
Is that available ?
I take it you mean lock the brakes? you should be able to if you are travelling fast enough, but take care.
