Author Topic: 2.0L Omega Auto box problem  (Read 1641 times)
Roger_Florance
« on: 31 December 2009, 08:08:32 »
Hi All
new member here, with a bit of a problem with my 2.0 L facelift Omega -Automatic -72,000 miles on clock
Slips out of gear when running downhill and the "check automatic gearbox" lights up on display and runs in limp home mode only -single gear. The local auto specialist say that this is apparently due to a collapsed spacer/thrust bearing that allows the gear clusters to drift forward hence dropping out of gear!
Is this a known problem and is the only answer a rebuild at £1000?
Regard
Roger F
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: 2.0L Omega Auto box problem
« Reply #1 on: 31 December 2009, 09:26:20 »
would be cheaper just to get another, seen some autos boxes for |£90. :y
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #2 on: 31 December 2009, 09:26:40 »
Where about's in the country/world do you live?
I like red cars
wideboy
  • ipswich
« Reply #3 on: 31 December 2009, 10:04:17 »
check ATF level first
Roger_Florance
« Reply #4 on: 31 December 2009, 10:10:30 »
Hi Auto Addict,
My location is about 11 miles east of Southampton, and yes I was offered another auto box from "find a part" but that was £350 plus delivery and of course there is also the cost for removal/replacement.
Perhaps I should look further for more realistic price
Roger F
Roger_Florance
« Reply #5 on: 31 December 2009, 10:14:53 »
Hi Wideboy,
Thanks for your response, yes have already checked ATF about two weeks previous to this, and auto box specialist did check it when I took it in for the diagnostic check, ta
Roger F
RobseyMV6
  • west sussex
« Reply #6 on: 31 December 2009, 11:07:02 »
What gear box is fitted to the 2.0 auto?
AR25 like the 2.5 omega?
If so i have one  :y
Roger_Florance
« Reply #7 on: 31 December 2009, 11:29:38 »
Hi RobseyMV6
I believe the 2.0L Omega facelift could have the AR25 auto box but I will need to double check, would be great news if it is!! and I see you are not that far away in West Sussex.
Will check it out and let you know if it is the right one.
 Ta
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #8 on: 31 December 2009, 13:26:49 »
Hi RobseyMV6
 Ta
It's an AR25.
I like red cars
