Author Topic: Water pump change  (Read 1473 times)
Eric DUBLIN
  • DUBLIN
Water pump change
« on: 06 January 2010, 20:57:21 »
Hey all:) quick question, I am about to replace my waterpump on my 2.5D (BMW) I'm just wondering what size torque socket do I need to save me buying a full torque set:)
Thanks in advance.
Eric
Re: Water pump change
« Reply #1 on: 06 January 2010, 21:00:09 »
its a 10mm from memory?
Or are you talking about torque wrench?
Eric DUBLIN
  • DUBLIN
« Reply #2 on: 06 January 2010, 21:15:15 »
No just sockets thanks.
Is there any other tools I need for this job before I start?
Thanks again:) so 10mm or T10 in other words?
« Reply #3 on: 06 January 2010, 21:18:35 »
T is torx. Not got a TD now, but sure it was 4 x 10mm bolts holding pump in place.
8mm to remove pully.
13mm (?) to remove pressure from tensioner.
32mm (?) to remove fan.
Hopefully someone can confirm sizes, as I'm going from memory
Eric DUBLIN
  • DUBLIN
« Reply #4 on: 06 January 2010, 21:21:42 »
Sorry I meant torx! Falling asleep here worrying about my car! Thanks for the info really appreciated:)
goonv6
« Reply #5 on: 06 January 2010, 21:23:07 »
Usually VX tensioners are 15mm but being a 'foreign' engine it might not be.
« Reply #6 on: 06 January 2010, 21:28:57 »
torx not often used on that BMW lump - its mostly standard metric bolts.
Eric DUBLIN
  • DUBLIN
« Reply #7 on: 07 January 2010, 00:34:13 »
Sorry just to confirm it's a 10mm torx? Or regular socket? Thanks:)
Eric DUBLIN
  • DUBLIN
« Reply #8 on: 07 January 2010, 12:12:38 »
Anyone as I'm about to start!
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #9 on: 07 January 2010, 12:17:21 »
10mm 'regular' type socket, Eric.
Personally, I use a 1/4" square drive set to do this job.
Page created in 0.024 seconds with 20 queries.
