Author Topic: Air Con blows cold air ONLY!!!  (Read 4113 times)
p j morgan
  • nottingham
Re: Air Con blows cold air ONLY!!!
« Reply #15 on: 05 January 2010, 00:06:59 »
have you tried resetting the aircon put your finger on the  off  and the auto button at the same time for ten seconds and you should here it restting its self  hope this helps ;) :y
arlee219
  • Birmingham
« Reply #16 on: 05 January 2010, 22:00:02 »
have you tried resetting the aircon put your finger on the and the auto button at the same time for ten seconds and you should here it restting its self  hope this helps ;) :y
On what and auto? :)
2.2 CD Auto LPG Conv Xreg
« Last Edit: 05 January 2010, 22:29:31 by entwood »
arlee219
  • Birmingham
« Reply #18 on: 08 January 2010, 20:46:22 »
Tried that already and it does nothing :(
Also could anyone tell me what does the manual mean by saying:
"Do not cover over the air vents when storing
items in the luggage compartment storage
compartments."
Where are those located in the boot?
« Reply #19 on: 08 January 2010, 21:52:18 »
Yes, the vents are found low down in the space  behind the panel that hides the First Aid Kit Holder, this is on the drivers side of the boot immediately behind the rear lights. If they are covered by anything, it causes the windows to mist up through inadequate air circulation:y
arlee219
  • Birmingham
« Reply #20 on: 09 January 2010, 12:05:48 »
wow
that I had no idea of
thanks a lot
I'll try and have a go at HBV vac pipe, but it's -4degr and I don feel like going outdoors
will keep you posted and thanks to all for all the hints you gave me so far
arlee219
  • Birmingham
« Reply #21 on: 10 January 2010, 13:15:41 »
can anyone tell me what was suppose to happen once I press OFF and AUTO alltogether. It does nothing at all. :(
arlee219
  • Birmingham
« Reply #22 on: 10 January 2010, 17:37:06 »
Right
Pressing OFF and Auto gives no change, but hey, I've found this on the net
http://www.vauxhallownersnetwork.co.uk/showthread.php?202901-Omega-HBV-Problem
The question I have is where are the matrix and another valve inside the car located? I checked the location described in the post, but found no valve or anything like it :(
