Author Topic: Halfrauds and glow plugs for 2.5TD  (Read 1585 times)
Dodger
  • Here in the sunny south!
  • I taught I saw a puddytat!!
« on: 09 January 2010, 20:24:34 »
Right, been having probs starting over the cold weather, from cold (sic). Car starts OK when warm, but from cold, at -4 struggles, almost flattening battery.. Garage diagnosis.. probable glowplug deterioration, suggest replacements.
Popped down to my local Halfrauds, and asked for the appropriate parts for the vehicle..
'employee' asks for cars details. ie: Vauxhall, Omega, 2.5TD, 1996 (N) reg...
replies, 'there isn't such a car'?? checks again, but no, their database does not hae a 2.5TD model listed??
2.5 petrol, 3.0 petrol, 3.2 petrol, no diesels at all!!! WTF???
'employee' asked for reg of car, and then tells me it's 'Vauxhall corsa, 1.4 petrol' according to their database, FFS!!!
So, have visited local factors, and been offered 6 Bosch glowplugs for the car (checked on their computer as correct (using reg no)) for £29 inc VAT,
or 6 NGK glowplugs for £42.50 inc VAT.
Any suggestions as to which to go for, or are VX's any better/worse??
Also, any advice regards changing them, or should I get the garage to do it (-4 here at mo, and if I do the job, it's got to be out in the road!!  :o )
Cheers guy's.  :y
I always knew I'd inherit an estate, but I never thought this would be it!
Re: Halfrauds and glow plugs for 2.5TD
« Reply #1 on: 09 January 2010, 20:27:11 »
last time i changed the ones in Tractor! I used NGK, and took me 50 mins start to finish (though no viscous to piss me off!!).
I guess Bosch should be fine
Welung666
« Reply #2 on: 09 January 2010, 20:46:41 »
I changed mine recently, still got the box if you want the part number, they were the NGK's I think :y
Dodger
« Reply #3 on: 09 January 2010, 21:16:16 »
Cheers Wellung, the NGK number I was quoted is :
Y-924J (3473), priced @ £42.50 for the 6
Just wondered if that was reasonable. Didn't want to get any 'cheap' ones from 'fleabay' as people said they were rubbish. Not too sure what the 'reasonable' price is for this sort of kit. Both Bosch and NGK are seen to be 'good' makes.  :)
damage consultant
  • falkirk (sunny scotland)
« Reply #4 on: 10 January 2010, 18:34:41 »
Go for the ngk's from local factors :y
the inlet manafold has to come off easy to do should only take you about a hour
be carfull not to twist the wires to much and get some instant gasket as well incase you tare the inlet manafold gasket :y
« Last Edit: 10 January 2010, 18:40:59 by senny »
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #5 on: 10 January 2010, 22:28:59 »
Fitted NGKs in my previous 2.5TD.
Got them from local factors for 28 quid, and still going strong two years later!
Page created in 0.029 seconds with 20 queries.
