Author Topic: RPM going up and down  (Read 2999 times)
Explorer
Re: RPM going up and down
« Reply #15 on: 10 January 2010, 14:32:09 »
i am afread of that the engine one day will stop in the middle of the street
« Reply #16 on: 11 January 2010, 00:50:48 »
ok, as previuos advise, perform the pedal trick to read any engine fault codes.
Your car has the same engine as mine. If the ecu sees a fault it will be recorded as a fault code which can be read via the pedal trick. Insructions and video here.  http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
read the codes and post them up, someone will translate them for you.
p j morgan
  • nottingham
« Reply #17 on: 11 January 2010, 01:21:55 »
i would check your air filter and the airflow meter and as said your breather pipes hope this helps? :y
Explorer
« Reply #18 on: 11 January 2010, 07:40:33 »
i alreday change the MAF sensor and air filter ,,
is there anything please need to be checked and if it is possible to provide the pictures ??
it is a sudden change only not all the time
Page created in 0.024 seconds with 16 queries.
