Author Topic: Blower current consumption  (Read 1693 times)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« on: 12 January 2010, 15:02:00 »
If I run my heater blower for a while on full speed without the engine running the battery goes flat Does the blower take that much current the battery is quite new
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Blower current consumption
« Reply #1 on: 12 January 2010, 15:03:22 »
what battery do you have on?
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #2 on: 12 January 2010, 15:26:41 »
Its 12v 66amp Banner
rustym95
« Reply #3 on: 12 January 2010, 15:28:56 »
how long did you havthe fan on? ingition was on to get the fan on you are powering the ecu's fuel pump etc.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #4 on: 12 January 2010, 15:30:53 »
Maybe 5-10 mins
« Reply #5 on: 12 January 2010, 15:32:46 »
Have a read of this and perform the tests. Battery shouldn`t go flat after 5-10mins http://www.omegaowners.com/forum/YaBB.pl?num=1225724099
rustym95
« Reply #6 on: 12 January 2010, 15:34:42 »
should not go the flat te quick, check that the battery is charged full, did you charge the battery from new or did you just put on car, as some batterys are half charged when you buy them, other than that alternator may not be charging the battery up properly.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #7 on: 12 January 2010, 15:35:55 »
Thanks will go through this and see what I can find
Page created in 0.022 seconds with 20 queries.
