Author Topic: Rear shocks  (Read 1415 times)
ians
  • Reading
Rear shocks
« on: 12 January 2010, 13:58:46 »
I likely need to change the rear shocks on my old Elite to get it through the MOT.  This car is just used as my mrs' runaround so we really have no need for self levelling.
If I install regular shocks (I'm looking at the Bilstein ones), I assume I need to disable the SL pump.  Is there a convenient fuse to pull or connector to undo?
Cheers,
Ian
Re: Rear shocks
« Reply #1 on: 12 January 2010, 14:07:31 »
I think it`s fuse #27. The connector will be under offside wing where the S/L pump is
« Last Edit: 12 January 2010, 14:08:39 by RobG »
ians
  • Reading
Re: Rear shocks
« Reply #2 on: 12 January 2010, 14:29:02 »
Is #27 in the drivers footwell?  ..and not going to take out anything else?
Re: Rear shocks
« Reply #3 on: 12 January 2010, 16:02:41 »
No, the compressor is all it feeds.  :y
Re: Rear shocks
« Reply #4 on: 12 January 2010, 19:14:20 »
...also runs the rear 12v socket, on my 52 plate saloon at least, will ians preface lift be differant? just out of interest...?
Re: Rear shocks
« Reply #5 on: 12 January 2010, 19:18:35 »
One of the 2 smaller relays by the cabin fuse box runs the compressor IIRC. Can always just pull that?
Long time no see, Ian. Trust you are well?
Re: Rear shocks
« Reply #6 on: 12 January 2010, 19:20:56 »
I will have another look at my preface lift, but I'm sure the fuse just does the compressor.  ;)
ians
  • Reading
Re: Rear shocks
« Reply #7 on: 13 January 2010, 09:31:29 »
Thanks chaps.
All well and good here Kevin - apart from another dose of snow overnight, getting fed up with it. >:(
I will have a fiddle later on when I brave the elements.
Going to have to tackle the powersounder on the 3.2 as well soon.
Page created in 0.717 seconds with 20 queries.
