Author Topic: Been told my drive chain is dry  (Read 875 times)
Tony O
  • Ormesby, Great Yarmouth
« on: 18 January 2010, 08:46:36 »
I ve been told my drive chain on 96 v6 cd is dry. I get a wering noise on start up which last for about 5minutes. I s this correct? If so how do I sort it.
Re: Been told my drive chain is dry
« Reply #1 on: 18 January 2010, 08:51:15 »
Sounds like someone is pulling your chain!!!  ;) Cams are belt driven.
The sound could be the secondary air pump, which should run for a minute or so on start up, could also be a dry fan/auxillary belt tensioner bearing.
« Reply #2 on: 18 January 2010, 09:30:42 »
Agreed. Someone either doesn't know his @rse from his elbow or hasn't bothered to lift the bonnet before making a disgnosis. Either way one to be avoided in future!
Worth looking into in case it is a cam belt tensioner on the way out. Worth running it briefly with the aux. belt removed to eliminate that IMHO. Check the feel of the aux. belt tensioner bearing while you're at it, as said.
Page created in 0.026 seconds with 20 queries.
