Author Topic: Hot water smell - Tried everything, please help.  (Read 4854 times)
cruisetopoland
  • UK
Re: Hot water smell - Tried everything, please help.
« Reply #15 on: 14 January 2010, 11:50:31 »
Funny thing is that it never, ever overheats! The temp gauge has never reached 95, its been on tickover now for 2 hours, no electric fan on at any time and even if left to run on tickover for many hours the electric fan does not cut in even then. The electric fan does work and the temperature switch for it is new and fully working. All that has already been looked at. The wiring circuit was tested and that is fine too.
I am going to leave it running on tickover now until it does show some signs of something.
Sods law, it must be.
cristina
The weather is very cold and if the grille vents etc are clear, it should run fairly cool on tickover for ages.
Mine ran without overheating too and with no noticeable coolant loss-just the smell, as a tiny amount of steam was escaping occasionally-not visible apart from a minute "salting" mark around the TINY crack.
Happy hunting  :y
ferrari jason
  • Skelmersdale
« Reply #16 on: 14 January 2010, 11:59:27 »
Might be a stupid reply but are you sure the smell isn`t coming from when the pipes were changed and the old colant went on the exhausts and engine etc and is just simply burning off I only say this because i did my exhaust the other week and i still get the odd whiff of burnt wd40 and thats over 3 weeks now
« Last Edit: 14 January 2010, 12:00:13 by roverjason »
cruisetopoland
  • UK
« Reply #17 on: 14 January 2010, 12:16:26 »
Excellent point-when I changed my stat, it took ages for the smell to go as the coolant dried off the casings and engine bay.
Not thought of that  :y
« Reply #18 on: 14 January 2010, 12:24:46 »
Not sure I have seen an answer to the coolant loss question so let me re-phrase it:
DO you ever have to top the coolant up?
Omega3
  • Hertfordshire
« Reply #19 on: 14 January 2010, 17:15:11 »
All my Omegas have had this occassional hot water smell. On the first car It was annoying and thought it might be a fault but never found one, on the second, 2.2 bought at 4 mths old, was suprised but started to think it must just be a niggle for the model and as there was no real coolant loss didn't bother looking for a leak. Had that car approx 2 years and never resolved it but it didn't seem to have any consequences. When my third omega occassionally had exactly the same smell from 5mths old I just put up with it as again I couldn't find any leak. The same smell wafts up from my 3.2, usually after a long run.
After reading previous post I'm going to check my header tank for cracks.
Previously: Mercedes CLK 320cdi, Insignia SRi, 53 Omega 2.2CD, 02 3.2 elite, 01 Omega 2.2CD, 94 Omega 2.0 Est, Mercedes 300TE, Toyota Supra 3.0, Honda Legend Coupe, Supra 2.8i Mk2, Fiat X1/9, Lancia Trevi
cruisetopoland
  • UK
« Reply #20 on: 20 January 2010, 12:49:19 »
Can anyone tell me why there is a smell of hot water inside the car? The inside of the car is bone dry and I cannot see any leaks at all from the outside. I have had my hubby look at it from underneath too. The Auxillary belt, Cam cover joints, HBV and thermostat were changed for VX ones because I was told that the VX parts were the best, I will always use VX parts in future for any repairs. The heater core and the rest of the system was pressure flushed out both ways as well until the water ran clean and clear. It has been fully antifreezed. The water circulates as it should, no bubbling in the tank and there are no funny noises. The oil is clean and the filler neck has a tiny amount of very light white film inside it for about an inch. The top up tank is also clean inside. The automatic choke works as it should too, it disengages in a few minutes.
My hubby took the plenum off so he could see better and when I looked there was nothing to see. We did all this with the enginge hot and then cold to see if that made any difference. It didn't!
What can we try next?
cristina
Did you sort this out?  What was it?
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #21 on: 20 January 2010, 13:22:34 »
I dont think you will find anyone on here recommend radweld or Barrs leak, i agree that the engine bay should be clean as when you do get a leak it will be easier to find and you dont get covered in crap doing the routine maintenance.
Again please confirm that you are not having to add small amounts of antifreeze every now and again, if you are then we maybe more able to advise you. I have seen in the past radiator hoses with the tinyest pin hole in them and when checked show no signs of problems but under full operating conditions they weep slightly and the water is evaporated by the considerable under bonnet temps the v6 produces.
More thing to considr i know but dont rule out anything yet as these fine beasts do tend to suprise us now and again. ::)
A previously owned XJ6 had a Service requirement to add Barrs Leaks at regular service intervals!!! :-/
cruisetopoland
  • UK
« Reply #22 on: 20 January 2010, 13:30:38 »
Quality engineering  ;D
markrl
  • London
« Reply #23 on: 20 January 2010, 16:00:43 »
You may laugh but I do believe TIS also refers to adding GM anti leak tablets to the cooling system after certain proceedures.
I dont think adding one dose of a leak stopper will do any harm but the problem is that there is a temptation if there is a continued leak to keep adding further bottles and then the problems start. It has to be strictly one dose only. Just like taking medication it has to be used as per the instructions. I appreciate the purists on here dont like it but the manufacturers themselves do seem to have their own version of it. It still sells so someone must be buying it, come on everyone own up  ;D
« Last Edit: 20 January 2010, 16:01:38 by markrl »
pedroMV6
  • York
  • Der Metzgermeister
« Reply #24 on: 20 January 2010, 18:42:03 »
Egg. :y
Break one into the header tank when cold.
Works far better than Barrs leaks etc.
cruisetopoland
  • UK
« Reply #25 on: 20 January 2010, 18:49:23 »
Egg. :y
OmEGGa?
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #26 on: 20 January 2010, 18:58:58 »
Sorry guys, dont agree with any substances for bunging up a leak, fix the problem ie the leak rather than blocking up the entire cooling system with crap. Half the time, although not all the time, the problems are there waiting to pop but they are not noticed., It is normal as the cars age that the hoses will start to go soft and deteriate but get ignored or over looked as a poss up coming fault
So my tip is to reg check all the coolant hoses where poss very carefully and at the first signs of coolant leaks change the hoses and clean the fitting of any crud and check or change the hose clips as well.
The rad is also subject to being checked as well and often the causes are easily seen. Basic maintenance is what it is all about.
Jaguar XJ6
