Author Topic: steering  (Read 3746 times)
evo1968
  • worcester,west midlands,englan
steering
« on: 18 January 2010, 23:11:19 »
does anyone have an idea what could be wrong with my steering..for the last couple of weeks when i am parking the car the steering goes really hard like the power steering has packed up,but when driving normally its fine??
unlucky mark mv6
  • tipton,west mids
Re: steering
« Reply #1 on: 18 January 2010, 23:26:48 »
As i said to matt earlier mate,check your tyre pressures,mine does exactly the same sometimes,because i have a slow leak in the passenger tyre,put some air in and its great again.I think the migs steering is very sensative. :y
peter19730
  • manchester
Re: steering
« Reply #2 on: 18 January 2010, 23:30:55 »
poss low fluid level
Dany
  • Belgium
Re: steering
« Reply #3 on: 18 January 2010, 23:37:11 »
+1 ;)
unlucky mark mv6
  • tipton,west mids
Re: steering
« Reply #4 on: 18 January 2010, 23:37:26 »
Oh yes definatly peter,forgot to mention the obvious first. :D :y
evo1968
Re: steering
« Reply #5 on: 19 January 2010, 19:43:46 »
tyre pressure and fluid levels are all correct,first things i checked.could the steering pump be nackered or rack..no leaking or anything though??
stevi1983
  • South West
Re: steering
« Reply #6 on: 21 January 2010, 21:43:07 »
Got the exact same problem with mine, every time when i go to park it seems the power steering packs up.....
Re: steering
« Reply #7 on: 21 January 2010, 21:50:54 »
Mine too! & I get a horrible grating noise on full lock most times but not all! :D :-?
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: steering
« Reply #8 on: 21 January 2010, 22:01:39 »
jack up both wheels, then if you can move the steering by one wheel, probably a ball joint going or somthing, should move easy by hand no need to use the power steering with engine running. :y
if nothing then try with the engine running and have so one move the steering wheel left lock to right lock.
« Last Edit: 21 January 2010, 22:04:32 by Russell_Hill »
alfie
  • Gwent
    • Mondeo Ghia estate tdci
Re: steering
« Reply #9 on: 21 January 2010, 22:15:08 »
Now do not laugh at this.
Last week my power steering stopped working after I had got myself stuck in the snow,miggys must be the worse car ever made for driving in snow.
But anyhow after checking everything out fuse fluid drive belts etc,a neighbour told me that his astra had suffered the the same problem a while ago,and he had traced it to a poor condition battery,rechare the battery and hey pesto problem solved.
Now i thought what a lot of balls,but next day another friend also told me much the same story only with his combo van.
So with nothing to lose,I charged the battery ,restarted the car and the steering worked perfect.
So before you spend any money,make sure your battery is in  tip top condition,as the engine managerment computer seems to want to shut down unnessesary systems to safeguard itself.
My own battery had a few dud cells,so its worth a try isn,t it .
                    Best luck Alfie.
ps its true it really did work.
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
Re: steering
« Reply #10 on: 22 January 2010, 05:34:14 »
What does it feel and sound like when you have the motor running and you turn it lock to lock? Whether jacked up or not it should be relatively silent and only whine quietly, it should be smooth and the only other noise should be the tyres scraping the ground. Does it sound chattery and feel lumpy? If so that is called cavitation and is caused by air in the system. Is there an ATF leak making it low on fluid? The pump itself could be on the way out. It could be the Aux belt too.
alfie says Migs are bad for driving in snow????
I am not trying to be funny but I find it strange to state that it is a bad car in snow. With so many driving aids included in my Elite auto I have found it to very good provided that the tyres are in good order and the driving technique is adjusted to suit the weather conditions and road surface. It is a very heavy car which makes driving technique even more important because it takes more power to get it moving and its harder to stop once it is.
I have never been stuck but do admit that on rare occassions, usually uphill I have had to use the snowflake button. This area is not known for good gritting practice either, the LCC council is so tight their asses have been stitched shut!
I have seen many 4x4s having problems due to the driver, not the vehicle.
« Last Edit: 22 January 2010, 05:42:09 by its.ray »
alfie
  • Gwent
Re: steering
« Reply #11 on: 22 January 2010, 08:45:19 »
Hello Bionic,Regarding my omegas dislike of snow,I live in the Heads of the Valleys area of Gwent.
When it snows it really SNOWS here,my cars finds it difficult to even pull away on a level bit of road let alone any kind of incline of which around here there are many.
Once you are on the move,you are ok, but its the start thats the problem.
                                   Regards Alfie.
evo1968
Re: steering
« Reply #12 on: 22 January 2010, 14:05:15 »
thanks for all of your thoughts,i will try them over the weekend,weather permitting,a bit wet down here. >:(
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: steering
« Reply #13 on: 23 January 2010, 17:29:28 »
Try changing the servotronic assistance relay located in the drivers footwell kick panal. these have :y a tendancy to intermittantly lose assistance at low revs.
Jaguar XJ6
Re: steering
« Reply #14 on: 23 January 2010, 18:34:42 »
                    Best luck Alfie.
Don't see why it mad a lot of difference to the Omega PAS... It's mechanically driven by a belt. The Newer Ashtrays and Combo's ar electro-mechanical PAS, so a poor battery would make a difference ;) ;)
As for Omega's in the snow... Don't understand the problems really, although I accept your comments further down, but I would have thought if you lived in an area which was that bad you'd have snow chains and make the relevant preparations ::) ::)
Page created in 0.041 seconds with 20 queries.
