Author Topic: TD cold start probs  (Read 2518 times)
OldTDowner
Re: TD cold start probs
« Reply #15 on: 25 January 2010, 21:53:44 »
Hi again and thanks for all the info!
Just one thing...is there a specific procedure for removal of the glowplugs? I have heard for example that No6 closest to the bulkhead is a bit of a pig...Does much have to be removed?
Thanks again...Mike.
PS..no I havent done the paperclip test yet.
OldTDowner
« Reply #16 on: 25 January 2010, 21:59:02 »
Just another thought...
When it does start it runs like a dream, so if a glowplug or two had gone, would it not also affect the general running of the car?
As I said...just a thought.
Mike
Welung666
« Reply #17 on: 26 January 2010, 06:03:22 »
Mike
No, the GP's are only used for a cold start, it's the fuel heater that's on and off as your running in cold weather :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #18 on: 26 January 2010, 08:56:59 »
Basically, you'll need to remove the inlet manifold and 'turbo diesel' plastic jobby.
I find it best to use a deep HEXAGON-type socket (rather than bi-hexagon type), as it reduces the risk of rounding-off the plug nut.
OldTDowner
« Reply #19 on: 27 January 2010, 20:13:29 »
Thanks for all help...
I'll do the glowplugs then next time I have some .(time)
I have heard also that sometimes a plug or two can ''fuse'' to the head...is that true? If so what on earth can be done then?? Would still like to know if there is a ''how to'' on this subject too if poss.
Thanks again in anticipation etc...  Mike.
