Author Topic: oil in water  (Read 1497 times)
Barry_B
  • Sunderland
oil in water
« on: 27 January 2010, 15:20:56 »
3.0. very heavy ''mayo'' in water header tank, no water in oil or on dipstick, is this more likely an oil cooler fault rather than ahead gasket ?
Re: oil in water
« Reply #1 on: 27 January 2010, 15:29:02 »
yep, oil cooler breaked.
Re: oil in water
« Reply #2 on: 27 January 2010, 17:13:43 »
Do not start the engine until you have managed to get it fixed... It'll just circulate the oily sludge and make it almost impossible to get cleared :y :y
ScottieMV6
  • Swinton, Manchester
Re: oil in water
« Reply #3 on: 27 January 2010, 17:28:47 »
Make sure you flush your cooling system very thoroughly once new cooler fitted :y
I'd rather be scared to death than bored to death!!
Re: oil in water
« Reply #4 on: 27 January 2010, 18:10:40 »
As you have guessed, oil cooler :y
Barry_B
  • Sunderland
Re: oil in water
« Reply #5 on: 27 January 2010, 23:33:23 »
thanks guys for your very speedy help, seems conclusive oil cooler is fault, sadly engine been run before fault discovered any particulaly good product available to use as flush?
hotel21
  • The Kingdom of Fife
Re: oil in water
« Reply #6 on: 27 January 2010, 23:35:37 »
Copious amounts of free flowing water and jizer or gunk to act as an oil emulsifier/flusher.
And thats both during and after the oil cooler has been replaced......   ;)
Re: oil in water
« Reply #7 on: 27 January 2010, 23:41:29 »
...and strongly advise correct size flair nut spanner for oil pipes, open ended spanner just buggers the nuts it seems.
There is a guide in maintenance i'm fairly sure.
