Author Topic: Steamy windows  (Read 7972 times)
SR-71 Blackbird
  • Watford and Nottingham Uni
Re: Steamy windows
« Reply #15 on: 22 January 2010, 21:22:42 »
hi i have a saloon and somtimes get this problem, when u say check the vents in the boot what do you mean? ie what do they look like and where are they  :)
Re: Steamy windows
« Reply #16 on: 22 January 2010, 21:37:26 »
Open the boot, look to the right, you will see a removable panel with a red cross symbol on it, open it & in the space at the bottom you will see two plastic vents. Make sure these are not covered over or blocked. Simples! :y ;)
Re: Steamy windows
« Reply #17 on: 22 January 2010, 21:38:25 »
They are in the rear wings, inside where the first aid kit should be on the right hand side ;) ;)
I had this problem last week but knew I hadn't cleaned the inside of the windscreen for a while... Cleaned it and it's now fine :y :y
Incidentally... If you use any type of cloth on the windscreen I find it happens, including chamois leather :o :o Oh... And I never use the eco button... The difference it makes is about 8 or 10 miles per tank and, IMO, not worth worrying about ;) ;)
SR-71 Blackbird
Re: Steamy windows
« Reply #18 on: 22 January 2010, 21:51:39 »
ok thanks guy, i know where you mean and i will check later when the sun comes up, its been raining heavily in nottingham today and i was next to a shop window and saw the alloys gleaming, its nice to see what the looks like when its slowly moving ;D
markh1
  • surrey
Re: Steamy windows
« Reply #19 on: 24 January 2010, 09:45:42 »
Sorry for the thread hijack but please could someone clarify something for me...
When the heater is on, unless the eco button is on is the aircon on?
Also will the aircons ability to demist be reduced if it needs a regass?
'98 Omega 3.0 Elite Manual - Slowly having most of running gear replaced
'98 TVR Cerbera 4.5 - completely rebuilt on new chassis
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Steamy windows
« Reply #20 on: 24 January 2010, 11:33:26 »
the misting up off windows is common at this time off year its due to the damp in the air. also cold colthes etc eg(glasses when you walk outside the mist up)  the aircon drys the humitdy out off the air and stops the misting up. it happens in my truck just wack aircon on all gone. also make sure pollen filter nice and dry. if matrix is leaking coolent level drops and carpets in rear get soaking wet.
Hoof'land storeman.
smoothomega
  • Perth, Western Australia
  • 2002 2.2DTI CDX,
Re: Steamy windows
« Reply #21 on: 24 January 2010, 14:45:57 »
Thanks for all your answers, been away from pc for a couple of days so just off out to try some of the suggestions before delving into the heater department, will keep you posted  :y
Thanks again
Jez
Re: Steamy windows
« Reply #22 on: 24 January 2010, 15:38:33 »
Eco button on = aircon off  :y
smoothomega
  • 2002 2.2DTI CDX,
Re: Steamy windows
« Reply #23 on: 28 January 2010, 15:50:12 »
Just to update, tried the MarkDTM prognosis and all is well now, clear windows  8-) A day later the battery managed to turn the engine over for about two revolutions before dying a death, so i am guessing that the battery was on its last legs and after starting in the morning the voltage was low enough that the recirculation flap was switching to the recirculation position and thus causing the problem. Fitted a new battery and now all is well again in omega land. Thanks Mark for your help and everyone else for your suggestions  :y
Jez
