Author Topic: cutting out when cold  (Read 2658 times)
caran10
  • coventry
« on: 24 January 2010, 12:37:12 »
my miggy keeps cutting out at low revs and seems to hesitate when accelerating , seems to improve when warm although still cuts out when idling. just changed crank sensor .
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: cutting out when cold
« Reply #1 on: 24 January 2010, 12:40:20 »
check the idle control valve. but that would bring a code up. you say you canged the crank sensor have you put all the vac pipes on and pluged all the sensors in.
Hoof'land storeman.
« Reply #2 on: 24 January 2010, 12:52:55 »
2.6 does not have ICV, was the crank sensor geniune?
Do the Pedal test to get some codes  :y
biggriffin
« Reply #3 on: 24 January 2010, 12:57:32 »
weather the part was gm or not dosent make a lot o differernce as only bosch and siemans make them.
Hoof'land storeman.
« Reply #4 on: 24 January 2010, 13:06:49 »
Lot of people have had issues with pattern sensors, which was fixed by genuine sensors.
Caran needs to get the codes read!
caran10
  • coventry
« Reply #5 on: 24 January 2010, 13:09:11 »
pedal test comes up 0100  0335  1512 thge same as before i changed the crank sensor  i sort of had this problem before the crank sensor packed up . used genuine v/w replacement
« Reply #6 on: 24 January 2010, 15:50:47 »
0335 crank sensor.  I put a new crank sensor on the saloon - genuine Vx from main dealer - lasted less than a month!!  Replaced with a used one I had - ok since!!
caran10
  • coventry
« Reply #7 on: 24 January 2010, 17:14:58 »
only fitted new one yesterday wouldnt run at all before
« Reply #8 on: 24 January 2010, 22:55:32 »
Could still be a dodgy one - code should clear if all is well with crank sensor.
caran10
  • coventry
Re: cutting outon tick over
« Reply #9 on: 26 January 2010, 19:34:40 »
cuts out every time i stop, give it some welli and it seems to clear for a while but then plays up again as if i have a fuel blockage
« Last Edit: 27 January 2010, 17:18:35 by caran10 »
caran10
  • coventry
Re: cutting out on tick-over
« Reply #10 on: 26 January 2010, 21:58:20 »
caran10
  • coventry
Re: cutting out on tickover
« Reply #11 on: 26 January 2010, 21:59:17 »
caran10
  • coventry
« Reply #12 on: 27 January 2010, 17:19:03 »
Koomorph
  • South London/Surrey
« Reply #13 on: 27 January 2010, 17:48:00 »
When you fitted the crank sensor, did you make sure it was routed away from the exhaust manifold and heat shield  - as best as possible (due to the short length of cable that comes with the sensor)?
Good pictures here from Mark here:
http://www.omegaowners.com/forum/YaBB.pl?num=1263833502/10#10
Wondering if the new one has developed a fault straight due to the cable running to close to the hot parts…
caran10
  • coventry
« Reply #14 on: 28 January 2010, 19:06:53 »
Quote from: 5F7B7B797B66647C140
[url
http://www.omegaowners.com/forum/YaBB.pl?num=1263833502/10#10[/url]
yes fitted the new sensor well away from any heat
did a tech 2 test today which showed lots of old faults . wiped them clean and did all the tests again and no faults showed . running better but still cutting out occasionaly on low revs ,wonder if i have some dirt in fuel , also did a pedal test and the light kept flashing continuously ,is this normal and means no faults ?
