Author Topic: xenon light replacement  (Read 1577 times)
brucellosis
  • n.i
« on: 26 January 2010, 22:25:06 »
hows it goin folks..?
happy new year by the way  :-[
ive a 2.5 td gls, im putting xenon headlights from a mv6 into mine, herd theres a bit of rewiring needing done???
can anyone help or advise, cause im sure someone else has done the same mod....step by step inst or pics would be great cause when it comes to doin this i feel like ive had my hands/fingers/arms/eyes/brain amputated  :o :o :y
cheers
« Last Edit: 26 January 2010, 22:25:47 by brucellosis »
Hannah Judes Dad
    • the misses round the bend
Re: xenon light replacement
« Reply #1 on: 27 January 2010, 01:30:27 »
I don't know what MOT regs are like in NI but over here to comply with the regulations you will need to have self levelling suspension as part of your set up so as not to blind oncoming vehicles.I hope this helps.
« Last Edit: 27 January 2010, 01:31:23 by hannahjudesdad »
« Reply #2 on: 27 January 2010, 09:25:46 »
Not quite as cut & dried as that.MOT test just tests the beam pattern isn't blinding on coming traffic.  :y
I_want_an_Omega
« Reply #3 on: 27 January 2010, 15:05:25 »
What age are the cars?
I did this to a 98 minifcelift CD, fitting the lights from an Elite. There are several versions of the truth on here about what's required. However, I:
1) Moved the headlights
2) Moved the "manual" electric levellers from the old headlights to the Xenons
3) Fitted headlight washers & new washer tank etc
It isn't as factory fit for sure, but an MOT tester told me tht he would pass it if presented, the beam pattern was ok and the levellers worked.
I have all the gubbins to do the self levelling but won't be fitting it as I dont "need" to & the wiring isn't in the vehicles sitting dormant. The Xenon ECU sits in the pointy bit of the o/s front wing, inside the wheelarch - so not the easiest of beasts to get at.
I set up the entire system on a bench and got it all working, ECU, sensors, wiring, levellers etc, so could fit it if I really had to. There is also a single wire connection to the MFD which would need to be replaced/TECH2'd to give the error messages from the Xenon ECU. I got a replacement MFD from an Elite as part of the kit.
Fitting the headlight washers was most interesting as I discovered that my car had previously had a front end bump which meant the bumper support brackets were twisted & needed replacing. You will need to plug in  relay to the fuse box and fit new trims below the headlights - in the correct colour.
If for any reason my car fails an MOT I'll just put the old headligts back in.
The wiring is slightly different and has a different connector for main beam supply - which you should remove frm the donor car with about 20cm of cable. The colours are the same so you can solder (dont use scotch bloks) and have the old & new connectors there at the same time aiding replacement in the future. Its really important to solder the joints properly as the Xenons take bout 20amps to strike the arc - this only reduces to the 3.5amp steady state current after a few mins. So coupled with the thick wiring you will need a pretty sturdy soldering iron for the joints - I used a 100watt iron.
HTH
« Reply #4 on: 27 January 2010, 18:14:11 »
HTH
The DfT rules are very clear, and have been covered numerous times.  However, current MOT does not test for this (but PC Plod can still nick you for it)
KillerWatt
« Reply #5 on: 27 January 2010, 20:18:46 »
As TB says, just because it meets the MOT regulations, that doesn't automatically make it legal to use on the road.
brucellosis
  • n.i
« Reply #6 on: 29 January 2010, 09:54:54 »
yeah its for a 2000 model.so guess its handy enough to do then
cheers folks
Page created in 0.022 seconds with 21 queries.
