Author Topic: Sump gasket  (Read 1052 times)
Bumbazor
  • Worksop
Sump gasket
« on: 29 January 2010, 09:40:56 »
Is it rubber or a sealant type? What's the part number?
Re: Sump gasket
« Reply #1 on: 29 January 2010, 14:15:55 »
You mean the lower steel pan? I was supplied (sold) some grey goo sealent/gasket in short a mastic type tube when I did mine.
Bumbazor
  • Worksop
Re: Sump gasket
« Reply #2 on: 29 January 2010, 14:25:11 »
Ah right ok I have some of that left over from doing my oil cooler. Must be high temp stuff that doesn't react with the oil.
Re: Sump gasket
« Reply #3 on: 29 January 2010, 14:27:37 »
You'll have to check it's the same  :-/, I've never done an oil cooler.  :y
