Author Topic: Gearbox Selector switch  (Read 1649 times)
plumber
« on: 27 January 2010, 13:24:40 »
Hello
I have got problems which my gearbox selector switch .Im planning on checking it my self before i buy a new one as it may just  need cleaning.The garge whats silly money to change it.
Is there a guide on this site on how to remove it and replace it .
Thankyou Tony
plumber
Re: Gearbox Selector switch
« Reply #2 on: 27 January 2010, 19:08:07 »
Thankyou Rob G
That was very helpful of you! Hopefully now i can start the job of removing the selector switch and see what sort of problem i face
Tony
plumber
« Reply #3 on: 27 January 2010, 22:45:49 »
Before i take off the selector switch which is what ive been told is the problem i thought i might check that it is the problem.
1, when driving along sometimes it comes out of gear and i have to use the gearbox manually .I then park up turn off the ignition and start it up again and i can use the automatic box as normal
2,same problem as above but i can press the sports mode button on the gearstick and carry on in automatic
Any ideas thanks Tony
« Reply #4 on: 27 January 2010, 22:50:11 »
Are the gear selector lights working as they should or do they flash or all illuminate at once (christmas tree effect). Has the ATF level been checked correctly?
« Last Edit: 27 January 2010, 22:51:03 by RobG »
plumber
« Reply #5 on: 28 January 2010, 10:18:11 »
Thanks Rob
The lights work fine .If ATF means gearbox oil then this has been checked and is ok.
Thanks Tony
« Reply #6 on: 28 January 2010, 16:07:47 »
Ideally need gearbox ecu read for codes, doesn`t sound like selector switch problems especially as your saying you can press sport button and all seems fine
plumber
« Reply #7 on: 29 January 2010, 12:36:59 »
Thanks Rob
Would the paperclip test help or do i need the garage to test the ecu with tech2
Thanks Again Tony
« Reply #8 on: 29 January 2010, 12:50:26 »
Paperclip won`t read gearbox :'(
Kai
  • Oxordshire
  • Just useless
    • Omega elite 2000
« Reply #9 on: 29 January 2010, 12:58:00 »
I have this same problem so i'v decided im going to have daz change the fluid and filter  :y let me know tho if you find another way  ;D
Guess I just couldn't stay away for the fourth time....
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #10 on: 29 January 2010, 13:05:53 »
Thanks Rob
Thanks Tony
Who checked the ATF Tony? This shows how it should be done: http://www.omegaowners.com/forum/YaBB.pl?num=1152783586 :y
plumber
« Reply #11 on: 29 January 2010, 13:32:39 »
Hi shackeng
When the problem first started .I got the oil change in the gearbox by my local garage.With dextron
Thanks Tony.
plumber
« Reply #12 on: 29 January 2010, 15:56:35 »
Hi again i have just been reading through this forum and someone had the same problem as me with the car going into limp mode.
It was suggested that it the selector switch but also it might  be the throttle sensor .Does that sound likely?
Thankyou
