Author Topic: Cylinder Heads.........Lots of Photos!  (Read 8853 times)
ScottieMV6
  • Swinton, Manchester
Re: Cylinder Heads.........Lots of Photos!
« Reply #15 on: 01 February 2010, 13:35:10 »
Ok. Thanks for the advice Kev. :y
I'd rather be scared to death than bored to death!!
« Reply #16 on: 01 February 2010, 14:04:16 »
Given the low value of a pair of 3.0 heads second hand...it might be worth sourcing a set of second hand heads (about 40-50 quid a head tops)
The damage in the quish area looks to be either foreign object (but, you normaly get more than one impact mark) or a casting failure....if the latter then a skim is pointless.
You could change just one head for a second hand one but....if skimming you need to do both heads to keep the compression ratios constant on all 6 cylinders
ScottieMV6
« Reply #17 on: 01 February 2010, 14:08:12 »
What is the quish area?
« Reply #18 on: 01 February 2010, 14:52:44 »
The squish area is the section in the cylidner inside of the head gasket fire ring....its the bowl which the fuel/air mix is comrpessed into at the top of the compression stroke
ScottieMV6
« Reply #19 on: 01 February 2010, 15:19:49 »
Have I got this diagram labelled up right? (sorry but I am still learning)
If that is correct then is this the damage in the squish area you were talking about?
If so then this is not damage but an oil smear. It is now gone!
Finally I have also found this damage on cylinder 2
What are the chances of this sort of damage being repaired?
« Last Edit: 01 February 2010, 15:24:10 by scottie7275 »
« Reply #20 on: 01 February 2010, 17:15:24 »
LOL that just goes to show how hard it is to diagnose from photos.
I think you have got the terminology right. Now, bear in mind that the fire ring area is the critical part of the gasket. This must compress the metal fire ring on the gasket to form a very strong seal to contain the combustion pressures. If there is any damage to this part of the cylinder head the gasket will blow again. Elsewhere, little nicks are not such an issue because the composite gasket material has a little more give in it, there is less pressure to contain and the gasket has sealant impregnated into it.
I would first get rid of the traces of old gasket and oil by scraping with a wooden or plastic implement and then perhaps a light rub down with a fine emery cloth. Then see if there is any pitting or narrowing of the fire ring areas.
megaomega123
« Reply #21 on: 01 February 2010, 19:30:42 »
This is a very interesting thread. Can I ask Scottie, did you do all the strip down with the engine in situ or did it come out? Just out of interest  :P
Bent valve
« Reply #22 on: 01 February 2010, 20:11:32 »
Are you sure thats an oil smear? I would have bet money on that being a porous casting :-?
« Reply #23 on: 01 February 2010, 20:40:16 »
Yes, that was the area of concern.
So, clean the heads really well, the pitting around the coolant passages I am not that worried about but, it just goes to show what damage water with poor antifreeze mixes can do
ScottieMV6
« Reply #24 on: 02 February 2010, 08:18:33 »
Strip down was done with the engine in situ. :y
ScottieMV6
« Reply #25 on: 02 February 2010, 15:34:10 »
Thanks Mark and everyone else. I am going to spend some time giving the heads a really thorough cleaning then i might just post some more pics before putting them back on the car! :y
« Reply #26 on: 02 February 2010, 16:42:15 »
I found using razor blades cleans the old gasket off well  :)
« Reply #27 on: 02 February 2010, 17:17:53 »
A scotchpad from a plumber's merchants is not a bad investment either.
ScottieMV6
« Reply #28 on: 02 February 2010, 17:39:05 »
I got 2 of those yesterday! ;D
« Reply #29 on: 02 February 2010, 21:14:16 »
I use the ones that magicaly appear in the cupboard....for both plumbing and cleaning head faces.
But yes, you need a blade to get the crudd off first, I have an old chisel that I use
Pages: 1 [2] 3 4  All   Go Up
