Pages: 1 [2] 3  All   Go Down
Author Topic: please help  (Read 4548 times)
Re: please help
« Reply #15 on: 02 February 2010, 16:34:34 »
Didn't think a 2.6 had an EGR valve ::)
found a unit on drivers side that is on a flexible mount and has water pipes going into it, the leccy connector was off , do you know what this unit is
Is it fixed to a bracket that is fixed to the inner wing, if so its part of the winter pack for the heater ;)
Re: please help
« Reply #16 on: 02 February 2010, 16:43:57 »
Good point  ::)  ;D
« Last Edit: 02 February 2010, 16:44:53 by tunnie »
Dave Elite
  • Ellesmere Port
Re: please help
« Reply #17 on: 02 February 2010, 16:45:43 »
Good point  ::)  ;D
Wrong again ;D
caran10
  • coventry
Re: please help
« Reply #18 on: 02 February 2010, 16:46:48 »
yes thats the one thanks ,so its not that thats causing my problem. thinking about it my screen heater hasnt been getting very hot , perhaps thats what was causing that
Re: please help
« Reply #19 on: 02 February 2010, 16:49:30 »
Winter pack helps the heater matrix get hot water quicker, if anything screen heater should be hotter than normal, Jimbob made a guide for flushing the heater matrix  :y
caran10
  • coventry
Re: please help
« Reply #20 on: 02 February 2010, 16:57:54 »
thanks for that but if 2.6 doesnt have an egr valve where do i go next
Re: please help
« Reply #21 on: 02 February 2010, 17:03:39 »
I was thinking of my 2.2 and other V6's when thinking EGR, my mistake  :y
When it cuts out, does it run rough, then die? or simply cut out cleanly?
caran10
  • coventry
Re: please help
« Reply #22 on: 02 February 2010, 17:06:46 »
yes it goes lumpy as if fuel is not getting through
Re: please help
« Reply #23 on: 02 February 2010, 17:09:29 »
Does it always do it? Does it drive fine for hours, but then cut out, or always lumpy on startup, then die?
Worth checking the fuel filter, drivers side i think, small cylinder object, up by the petrol tank, should be changed every couple of years, that could be blocked.
caran10
  • coventry
Re: please help
« Reply #24 on: 02 February 2010, 17:11:48 »
changed that about 14 months ago about 9000 miles
Re: please help
« Reply #25 on: 02 February 2010, 17:13:49 »
just out of interest do you know the part number of the crank sensor the dealer gave you? Its not unheard of for a Vx dealer to give a 2.5 V6 sensor instead of the 2.6.
No idea what difference there is, but they have different part numbers, so must be different  :-/
caran10
  • coventry
Re: please help
« Reply #26 on: 02 February 2010, 17:13:52 »
sometimes i run for about 4 miles and its fine . if i leave it for a little while and run it again it starts playing up
Re: please help
« Reply #27 on: 02 February 2010, 17:16:33 »
still sounds like crank sensor, post up the part number of the sensor they gave you  :y
caran10
  • coventry
Re: please help
« Reply #28 on: 02 February 2010, 17:24:29 »
cant find the receipt but the part no. was the same as the one i took off
« Last Edit: 02 February 2010, 17:24:54 by caran10 »
Re: please help
« Reply #29 on: 02 February 2010, 17:37:05 »
Bang goes that theory then  ;D
Drop a PM to MarkDTMCalib, he is in Coventry fair bit, might be able to take a look, he also has tech2, and knows how to use it  :y
Pages: 1 [2] 3  All   Go Up
