Author Topic: Outside temp sensor  (Read 3307 times)
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
Outside temp sensor
« on: 01 February 2010, 12:46:25 »
Right, I'm getting really hacked off with mine!! It recently started working only intermittently so since then I've tried 2 spare temp sensors and connectors and repaired a connection in the wires with a good connector and now it doesn't work at all, all I get is "F" in the MID. I can only think there'e possibly another bad connection further back in the wiring loom or something else is amiss. If anyone has any further idea's I'd be grateful as it's playing havoc with my climate control. :'(
StevieP
  • Northamptonshire
Re: Outside temp sensor
« Reply #1 on: 01 February 2010, 13:45:39 »
Hiya,
Im having the same problems, changed my sensor and still getting an F in the display.
Lets hope someone can give us some advice, PM me if u find a solution.
Steve - Northants
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 01 February 2010, 17:38:11 »
mine was giving "F" FOR quite a well bought a new sensor all fixed.
Hoof'land storeman.
Dany
  • Belgium
« Reply #3 on: 01 February 2010, 18:12:24 »
Perhaps seeing the problem with the Tech2?
I also have an "F" on my CID, I have not replaced my sensor but my heater does not heat anymore, unless I select "HI", but if I choose a temperature, I have cold air... Is there a link between two things?
« Last Edit: 01 February 2010, 18:15:56 by moudufond »
megaomega123
« Reply #4 on: 01 February 2010, 18:52:12 »
Pretty sure there is no connection with the outside temp sensor. The climate control has it's own air temperature sensor behind the panel. Could be that yours is blocked.
Dany
  • Belgium
« Reply #5 on: 01 February 2010, 22:13:11 »
Yes I think you're right... I must to check that... But it's weird, it happened at the same time...
« Last Edit: 01 February 2010, 22:14:28 by moudufond »
« Reply #6 on: 01 February 2010, 22:15:50 »
Prefacelift car's outside temp sensor is stand alone.
Facelift cars use the outside temp sensor for he display AND for the climate. Or so the clever ones here say!  ;D ;D ;D
Dany
  • Belgium
« Reply #7 on: 01 February 2010, 23:11:49 »
I personally don't know Andy... I think all is possible.
Dany
  • Belgium
« Reply #8 on: 04 February 2010, 19:35:25 »
Today my display show the outside temperature again... The "F" has disappeared from itself...
hawksy
  • crewe
« Reply #9 on: 05 February 2010, 14:38:06 »
i had same problem with my 2.2dti  display read f then worked for a while then was reading f all the time and it affected the climate control , turned out to be a broken wire somewhere between outside sensor and in car display , cost £ 200.00 at vauxhall dealer as broken wire was not in an easy to get at place
Dany
  • Belgium
« Reply #10 on: 05 February 2010, 17:59:48 »
It displayed 68°C today... Waw!
Clouseau
  • Telford
  • Keeping the dream alive...
« Reply #11 on: 05 February 2010, 20:07:43 »
Been there!  It'll be a broken wire, probably close to the sensor or the loom connnection plug. Mine was broken inside the insulation, about 2 inches from the multiplug.  There are only 2 wires to the sensor (IIRC) - cut em out and splice some new ones in!
