Author Topic: LSD identification  (Read 3667 times)
Re: LSD identification
« Reply #15 on: 06 February 2010, 00:40:16 »
Can be a bit difficult to tell sometimes LSD with an Auto, best test is to find a country lane or simular, TC off, park one wheel on muddy or dirt kerb and give it full pedal, the other wheel parked on the road will start spinning and smoking if its got LSD followed with some back end swaying whilst your pulling away, assuming you kept the revs up.
All good fun, wet leaves on the road seem to work well also.  :y
Yep, or pull out of a T junction with far too much power and no TC on, and see if you end up driving up the road with your arms crossed, and trying to see round the tax disk. ;D
« Reply #16 on: 06 February 2010, 00:51:53 »
But I can do that in my Elite... If I'm really trying ::) ::) ::)
« Reply #17 on: 06 February 2010, 10:58:59 »
The 2001 'Y' 3.2 V6 auto red ex police has this sticker on the diff, it reads;
GF 085 0 A 32
8 S 10:39 26 10
I saw Tunnie today, and from driving the vehicle he thought it may be possible it had a LSD, does the sticker confirm this?
Many thanks.
LSD
Knew it, not completely useless after-all  ;D
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #18 on: 06 February 2010, 14:20:56 »
most plod cars have LSD and they also dissconect the T.C. which is put back when the leave service. the plate on the diff tells weather it has LSD look in haynes book as tells you in there.
Hoof'land storeman.
jb
  • bucks
    • 3.2 Elite
« Reply #19 on: 06 February 2010, 18:53:58 »
Too much lsd clutch bite gives the judder,best to renew fluid and gm friction modifier at 60 k intervals.
deejaywardy
  • Grantham
« Reply #20 on: 06 February 2010, 19:02:24 »
my 3.2 manual ( ex-police ) has a LSD  :y lots of fun and very quick  :y lol
« Reply #21 on: 07 February 2010, 11:16:57 »
Most might be a bit optimistic, but certain a fair proportion :y
pedroMV6
  • York
  • Der Metzgermeister
« Reply #22 on: 07 February 2010, 11:24:59 »
If it's fitted with an LSD you should be able to leave a decent number 11 on dry tarmac when pulling away, erm, "enthusiastically", from a standing start.
No LSD will leave a number 1........mind you, you'll get this if the LSD is not working!
You can also check by removing a driveshaft and looking into the diff casing - if you see an 'X' then you got LSD. :y
On good authority, not all ex-plod Omegas were fitted with LSD either. Mine isn't!
Humpy
  • Tunbridge Wells, Kent
« Reply #23 on: 07 February 2010, 11:30:55 »
Jack the car up and see if both wheels go round in the same direction when you turn one wheel. If so it's a slipper! The Monza GSE's had them, great fun :y
Humpy
