Author Topic: vac tubing  (Read 1186 times)
megaomega123
vac tubing
« on: 09 February 2010, 16:37:44 »
Does anybody know where I can get, or a good alternative, vac tube?
Due to poor routing and mounting my aux belt has warmed one in half  :-[
Re: vac tubing
« Reply #1 on: 09 February 2010, 16:39:04 »
PM Darth-Loo-Knee or Elite Pete  :y
megaomega123
Re: vac tubing
« Reply #2 on: 09 February 2010, 16:41:16 »
Cheers Tunnie  :y Anything that will suffice for now, as I have no multiram and could do with a bodge fix until I get the right stuff.
Re: vac tubing
« Reply #3 on: 09 February 2010, 16:42:36 »
Not worth bodging, Loo-Knee has broken fair few Omegas recently, so hopefully has some Vac pipes about. Otherwise check with the other breakers  :y
megaomega123
Re: vac tubing
« Reply #4 on: 09 February 2010, 16:46:15 »
No probs. I'll pm both now. Thanks again  :y
Debs.
Re: vac tubing
« Reply #5 on: 09 February 2010, 17:05:57 »
If you need a repair ASAP; then, motor factors often have a choice of various diameters of thick-walled rubber hose with which you could make a join of the existing (broken/worn-through) plastic length.....you shouldn`t need any clamps on the repair piece, as long as the rubber portion is a tight sliding fit over the outside of the old plastic pipe. :y
Re: vac tubing
« Reply #6 on: 09 February 2010, 17:19:16 »
Agreed. I have repaired them like this before. Just take a bit of the plastic pipe to a decent motor factors and find some rubber hose that is a nice tight fit. :y
dbr
  • north east.
    • 1997. 2.5CD petrol
Re: vac tubing
« Reply #7 on: 09 February 2010, 17:32:57 »
+ some sealant. works well
megaomega123
Re: vac tubing
« Reply #8 on: 09 February 2010, 19:17:30 »
Thanks everyone, have just purchased a good length off mutantcav.
Will be routed well away from aux belt ha!!
