Author Topic: Brake pad warning  (Read 1904 times)
mick11
  • Driffield, East Yorkshire
Brake pad warning
« on: 12 February 2010, 13:39:25 »
Getting an intermittent brake pad warning. How much wear is likely to be left. No nasty sounds or effects on braking, and only normally do a few local miles per week.
Re: Brake pad warning
« Reply #1 on: 12 February 2010, 13:41:26 »
could be a loose sensor, usually fair decent amount of pad left. This was how much pad was left on mine when the sensor was close to being set off:
  • Auckland
    • Mazda MPV
« Reply #2 on: 12 February 2010, 13:50:05 »
This was how much brake material was left on mine 2 weeks ago (and the pad sensor hadn't gone off). :o
If the warning is coming and going I would suspect a dodgy connection or that the warning is permanent and your MID also wants to tell you that the temperature is close to freezing.
Check your brakes now! We don't like losing members unnecessarily  ::)
« Reply #3 on: 12 February 2010, 14:03:43 »
Intermittent is unlikely to be wear sensors wearing...
Visual check it I'm afraid
ians
  • Reading
« Reply #4 on: 12 February 2010, 14:15:36 »
Am I missing something on that picture.. ::)
Bixy1
  • Leeds. West Yorks.
  • Hanging by a thread . . .
    • Diesel Vectra eventually.
    • Cats Tails
« Reply #5 on: 12 February 2010, 14:43:22 »
Only the lining!  ;D Now thats getting value for money!! lol
Cats Tails (The Adventures of Rommy and Reemy)
http://sbpra.com/derektmorgan
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« Reply #6 on: 12 February 2010, 15:04:13 »
One of the little spring things .... does it matter if that falls off  :-/
mick11
« Reply #7 on: 12 February 2010, 15:39:53 »
Thanks guys, will have to get them checked Im not up to pulling wheels off these days. It has started since the freezing weather.
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
« Reply #8 on: 12 February 2010, 16:12:55 »
The sensor wire flexes as the steering turns and has a connector clipped behind the Macpherson strut.  Could be ingress of moisture if the rubber seal has gone but most likely wire fracture.
Sensors give very poor indication of pad depth as the disk tends to get a ridge around the edge after several k miles that cuts through the sensor very early.
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #9 on: 12 February 2010, 16:46:30 »
pm me next time your down in hull and i will have a look for yeh  :y
  • Auckland
    • Mazda MPV
« Reply #10 on: 12 February 2010, 16:48:57 »
Yes it does matter. It pushes the pad into the fixed caliper frame.
If the spring is missing the pad rattles about and can jam or can slide away from the piston which ends up 1/2 on & 1/2 off the pad.
