Author Topic: Head Gasket Change...update!  (Read 7589 times)
Re: Head Gasket Change...update!
« Reply #45 on: 12 February 2010, 17:01:48 »
Where your followers noisey?
I assume then if they were not noisy they don't need servicing?
Yep
I would at least squeeze the oil out first.
If the valves have been reseated then the followers need to be compressed otherwise they will remember the previous learned valve clearances (which won't match the reseated valves) and might result in no compression.
They will be fine......on these hardened seats, you cant take owt off them and within a few turns of the cam, they will have leake down enough  :y
  • Auckland
    • Mazda MPV
« Reply #46 on: 12 February 2010, 17:26:45 »
Yep
They will be fine......on these hardened seats, you cant take owt off them and within a few turns of the cam, they will have leaked down enough  :y
That's good to know :y
Pages: 1 2 3 [4]  All   Go Up
