Author Topic: ABS ECU  (Read 4090 times)
goonv6
Re: ABS ECU
« Reply #15 on: 15 February 2010, 13:43:41 »
By the last 2 do you mean the bottom 2?
Takes perseverance mate - when I did the Estate never thought about removing abs block - can need use of Tech2 to bleed when refitted!!  All I removed was top hose, nothing else!
[edit]If its yours on ebay mate you need to get a move on!! ;)[/edit]
And finished. Still can't see how you did it but If I remember correctly, you're the guy who did his HBV without removing the scuttle.
Re: ABS ECU
« Reply #16 on: 15 February 2010, 14:09:40 »
No mate removed scuttle to do HBV and still bear the scars!!
Re the abs ecu I have largish hands but used a good selection of tools - needed a bit of creativity!!
