Author Topic: coil pacl v6 2.6 omega 03 reg  (Read 2643 times)
Re: coil pacl v6 2.6 omega 03 reg
« Reply #15 on: 16 February 2010, 16:12:24 »
Hence I was not replying to that, I know all to well that 2.4.6 is the brake servo pipe side (see what I did there....no reference to drivers, passengers, left, right, port starboard or wot)
Which end of the brake servo pipe would that be? :P
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« Reply #16 on: 16 February 2010, 16:18:17 »
Changed mine a few weeks ago... it is stamped on the coil pack which cylinders they are for - it's easy to read on the 1-3-5 side, but is obscured by the DBW trickery on the other... Straightforward job to change on the 2.6, except a bit fiddly to get the DBW wiring tray open in the cold weather!
There's also a cylinder layout stamped on the top of my block at the left hand side, looking from the front of the car  :y
Previous GM Models include '00 Omega 2.5 CD Auto, '06 Holden Commodore Executive 3.6 Auto, '99 Astra 1.8 CDX Auto, several Astra Diesels.
« Reply #17 on: 16 February 2010, 17:41:36 »
Sorry, didn't mean yes, its the drivers side,  .....
 :-?  :-?  :-? Still 4r$e about t1t!
2 4 6 coil pack is the passenger side! ie LEFT as you're sat in (which ever side of) the car  :y
Right, must be a translation into Bury thing (or out of Leicestershirean)
Sorry, didn't mean 'yes, its the drivers side'.
Hence I was not replying to that, I know all to well that 2.4.6 is the brake servo pipe side (see what I did there....no reference to drivers, passengers, left, right, port starboard or wot)  ;D ;D ;D ;D
As long as that all clear then!!  :-/  ;D
« Reply #18 on: 16 February 2010, 18:20:55 »
pmsl,
246 is the cable tray side (1 hour and a battle)
135 is the fuel line side( easy job )
screw an appropriate size bolt into the the brass insert in the pack to pull them/it out. Avoid levering with a screw driver...
Page created in 0.055 seconds with 16 queries.
