Author Topic: TC light comes on when accelerating hard at speed  (Read 5033 times)
MV6Matt
  • London
    • No car since 2022....
Re: TC light comes on when accelerating hard at speed
« Reply #15 on: 19 February 2010, 13:17:31 »
No. But worth paperclipping once a week or so, just to keep an eye on if that pesky 19 appears.
>>TB - bit confused   :-?- I'm on 19" rubber - the code is 21 not 19
Worth looking into the TPS - the engine and ABS ECUs talk a lot, and I reckon a flickering TC light was the warning sign of my crank sensor. So its possible the engine ecu is upsetting/confusing the ABS ecu when running in an 'error/recovery' program
>> Ok my TC light doesn't flicker but stays on when booted. Clears after restarting. Will keep an eye on TPS
Ta Matthew
(thanks Ian)
« Reply #16 on: 19 February 2010, 13:28:58 »
Just a thought .. if you are on 19" wheels .. and the standard wheels are either 15", 16" or 17", unless you have REALLY skinny tyres your overall wheel/tyre circumference will be somewhat larger than standard.
Now under hard acceleration the engine will attempt to speed up at a certain rate, controlled by the ECU, but the wheels on your car being larger, will not achieve that ...  Could it be that the ecu is "expecting" the wheels to rotate at a certain rate, and the ABS sensors detect the wheel rotation being slower and so flag up a fault ???
« Last Edit: 19 February 2010, 13:30:43 by entwood »
« Reply #17 on: 19 February 2010, 14:38:35 »
Ta Matthew
Ah, right :y
I think you probably need to get the ABS ECU codes read.  Not sure where in London you are, but I'm near Northampton, Kevin Wood is near Alton/Hampshire.
  • Auckland
    • Mazda MPV
« Reply #18 on: 19 February 2010, 16:22:50 »
I think MotoGP bikes monitor how quickly the rotation of the rear wheel is increasing to control wheelspin because they havn't got anything else to monitor (they can't rely on the front wheel it is off the ground half the time)
I think the Omega just compares instantaneous rotation of one back wheel to the other (and perhaps to the front as well). If it was looking at rotation increasing too quickly then a larger rolling radius would reduce the effect (not make it more sensitive).
I don't see why increasing too slowly would imply wheelspin.  :-/
« Last Edit: 19 February 2010, 16:26:42 by andyh »
« Reply #19 on: 19 February 2010, 16:35:13 »
Omega learns its wheel sizes over the first couple of miles, so thats never an issue.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #20 on: 19 February 2010, 20:08:19 »
try to acclerate a bit slower. its not a jelly mould corsa. would check the tps sensor as thats the code your getting.
Hoof'land storeman.
MV6Matt
  • London
« Reply #21 on: 20 February 2010, 08:53:16 »
OK thanks for all the advice - as it's Cambelt time next month I will get the TPS checked out as well as ABS ECU at same time.
I will see who's available on here and get it all done at same time I guess. ;)
Thanks again :y
Matthew
(thanks Ian)
