Author Topic: grinding sound on right turns....  (Read 3616 times)
« on: 20 February 2010, 18:57:03 »
Think i broke something on the 2.2  :( - Some moron who decided to use the left hand lane on a round-about to go all the way around to get to the M40 services  >:(
Slammed on the brakes, 40-0 stop almost instantly, fair play to the guy behind me he was close, but avoided hitting me.
After i filled up with some motion lotion, turning right pulling out, heard this awful grinding noise  :o
Seems to be on right hand turns (far as i can tell) and its metal/grinding on metal, it increases with speed. Tested it going round a mini-roundabout a few times, its quite loud, without the windows down its very noticeable  :(
Does not seem to do it on left hand turns, but not found any left hand round-abouts to test it on  ::)
I am thinking wheel bearing? - I did have a fair bit of left lock on when i stomped on the brakes.
Thinking about it, i should have not braked so well, and taken him out  ;D
Re: grinding sound on right turns....
« Reply #1 on: 20 February 2010, 18:59:36 »
Got Any meat left on yer brake pads?
« Reply #2 on: 20 February 2010, 19:01:09 »
fresh ones put on just a few weeks ago....
« Reply #3 on: 20 February 2010, 19:04:13 »
Stereo loud enough?
« Reply #4 on: 20 February 2010, 19:06:08 »
did have the Kaisers on earlier, this sound would be heard, felt with it on  :(
Its fine in a straight line, which is lucky as thats most of my commute.  ;D
Debs.
« Reply #5 on: 20 February 2010, 19:15:12 »
Might you have broken a spring with that heavy bout of braking? :-/
guncharmer
  • York
« Reply #6 on: 20 February 2010, 19:16:15 »
My guess,you have wear on the discs and an outer and inner lip is present.The sudden and hard braking has altered where the pads normally sit  and on  the right hand turns the pads are coursing the lip or lips.
« Reply #7 on: 20 February 2010, 19:20:33 »
could be Debs, its too dark to check now  :(
If i shifted the pads, thought that would have done it on left turns too?  :-/
guncharmer
  • York
« Reply #8 on: 20 February 2010, 19:56:13 »
Not neccessarily,do you have wear on the discs?
« Reply #9 on: 20 February 2010, 20:23:06 »
Discs are 2 years old, just put fresh pads on couple of weeks ago, slight lip on the pads, nothing big.
« Reply #10 on: 20 February 2010, 20:28:38 »
checked rear pads? maybe pads come unbonded?
Jack it up, should be easy to locate.
Oh, and dont use it!!
« Reply #11 on: 20 February 2010, 20:29:57 »
sound is defo from the front, front left i think.....
Stealing borrowing the 3.0 tomorrow, oh and i have nicked your Vax  :y
« Reply #12 on: 20 February 2010, 20:31:55 »
She said.  I must have nodded off - I didn't hear you :o
« Reply #13 on: 20 February 2010, 20:32:43 »
Check the front pads then.  Then check the back.
« Reply #14 on: 20 February 2010, 20:34:11 »
will strip down and inspect on Monday  :)
