Author Topic: Adjusting the throttle cable?  (Read 1252 times)
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
« on: 20 February 2010, 13:30:37 »
Hi all,
I'm no mech or tech when it comes to cars, so bear with me please!
I have a facelift 2.5 Elite saloon.... can you adjust the tension on the throttle cable at all?
When driving there is play in the pedal before I get any power, I've looked under the bonnet and found that there is quite a bit of play in the cable that is exposed just before it ends at a ball joint???
Thanks for any advice, Dave  :-/
AKA - Mr Bracket
Re: Adjusting the throttle cable?
« Reply #1 on: 20 February 2010, 20:32:21 »
Make sure that there is atlaeast some slack left in the cable if you decide to adjust it.  :y
blackviper90210
« Reply #2 on: 20 February 2010, 23:39:29 »
Will do, but how can you adjust it?
AKA - Mr Bracket
« Reply #3 on: 21 February 2010, 08:49:49 »
I'll have a look later if it stops snowing  ;D, but there's not the old style threaded end on the cable if that's what you're looking for. As far as I remember, you have the choice of about 3 or 4 postions on a rubber sleeve.
