Author Topic: fault codes  (Read 1426 times)
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
fault codes
« on: 20 February 2010, 16:38:31 »
hi
just done paperclip test and got fault codes 49 and 57............ 49-battery voltage high and 57-idle air control voltage low.......... how do i cure these??????
thanks
jiho102
  • Newmarket
    • 2.6
Re: fault codes
« Reply #1 on: 20 February 2010, 17:07:10 »
49 Battery not sure but could be alternator.
57 Low voltage usally means no power getting through so make sure everything is plug in propley.
I'am sure more experianced people will be along soon to help. :y
Re: fault codes
« Reply #2 on: 21 February 2010, 00:28:04 »
Measure the battery voltage at a fast idle with not too many electrical loads on. If it's over about 14.5 volts you probably have a failed regulator module on the alternator.
fiend61
  • york
  • each to their own
Re: fault codes
« Reply #3 on: 21 February 2010, 10:40:09 »
cheers kevin, will try that when it stops snowing!!!!!!  :-/
fiend61
  • york
  • each to their own
Re: fault codes
« Reply #4 on: 21 February 2010, 10:44:05 »
back to code 57 surely if the idle control wasnt getting enough voltage my idle would be all over the place? as it is the idle is steady and good  :-/
Re: fault codes
« Reply #5 on: 21 February 2010, 10:50:12 »
Do the battery check as Kevin Wood says :y
Is the idle rock solid, or does it fluctuate?
hotel21
  • The Kingdom of Fife
Re: fault codes
« Reply #6 on: 21 February 2010, 11:47:04 »
Think its related to a previous Q from the chap...
http://www.omegaowners.com/forum/YaBB.pl?num=1266678894
Revs all over the place and the dash lights up quite prettily....
