Author Topic: xenon headlamps  (Read 2682 times)
Re: xenon headlamps
« Reply #15 on: 21 February 2010, 14:28:44 »
if the car was fitted with xenons then yes the self  leveling system has to work.
  if the xenons are retro fitted to a car that did not have them fitted then self leveling not needed. its in c.u. regulations
Not quite true ..  :(
http://www.dft.gov.uk/pgr/roadsafety/drs/hidheadlamps
Its a longish article so I'll only quote a bit of it ...
Therefore a HID headlamp unit sold in the after market should:
1. be type approved to ECE Regulation 98 as a component.
2. when fitted to the vehicle should enable ECE Regulation 48 to be complied with (although no government inspection will take place).
3. Comply with RVLR as far as "use" is concerned.
In practice this means:
1. The headlamp unit (outer lens, reflector, bulb) shall be type approved to ECE 98 and be "e-marked" to demonstrate this. That can only be done by the headlamp supplier - Hella, Valeo etc. who must test the headlamp in an independent laboratory.
2. Once fitted to the vehicle it must have headlamp cleaning and self-levelling (which can be for the headlamp or can be in the vehicle suspension - some expensive estate cars have "self-levelling suspension" and that is adequate). Also the dipped beam must stay on with the main beam.
3. The headlamp must be maintained in good working order, kept clean, and aligned/adjusted correctly like any other headlamp.
Under the Road Traffic Act 1988 it is an offence to supply, fit or use vehicle parts which are not legal.
