Pages: 1 2 [3]  All   Go Down
Author Topic: Steering Idler  (Read 5372 times)
davethediver
  • Blackburn, Lancs.
Re: Steering Idler
« Reply #30 on: 08 February 2010, 17:54:00 »
i ve just changed mine(well tried)Two hammers, pitman arm removal tool, nothing i tried would get it off. Put the nuts back on, took it to the garage :D
Is this not the arm on the drivers side and not the Idler :-?
P.A. Caron de Beaumarchais
charlie
  • sunderland
Re: Steering Idler
« Reply #31 on: 08 February 2010, 18:01:17 »
yes dave,thought i try the tool on the idler on the off chance,but it wouldn't work :'(
fingers21
  • march, cambs
Re: Steering Idler
« Reply #32 on: 10 February 2010, 21:18:08 »
I tried to get mine off today, nuts came undone easier than i expected, it dropped off one end on its own (it really was knackered!) but the joint end won't come off. i tried cracking it, joint splitters, big bars to lever it off, nothing! Wouldn't budge, just laughed at me! I did it all back up and walked away as i was freezing in the snow! I almost got to the point of grinding it off, but managed to control my temper and stop myself!
Re: Steering Idler
« Reply #33 on: 10 February 2010, 21:30:12 »
Take it off at the body work end....rotate it so its in line with the link arm.....bash a wedge between it and the bar to apply some pressure (does not need to be excessive)
Then take 2 hammers.....hit either side of the idler arm adjacent to the balljoint taper with the hammers at the same time.....
Do it a few times and it will just pop off
manny
  • bromorough.Wirral.
Re: Steering Idler
« Reply #34 on: 10 February 2010, 22:29:55 »
What i did was take nut off bottom of idler then screw back on a couple of turns. Then get a bar and wedge it between car and track rod end then hit the idler upwards with bloody big hammer. Takes a few goes but will come off. The ball joint spliter wont fit in small gap.
2001 OMEGA MV6
manny
Re: Steering Idler
« Reply #35 on: 10 February 2010, 22:32:15 »
forgot to say that you push down on bar while hitting idler up.
2001 OMEGA MV6
Blackie_No1
  • Ballyclare N.Ireland
    • Omega Elite 2.5
Re: Steering Idler
« Reply #36 on: 18 February 2010, 22:20:57 »
Oh joy, I have all of this to look forward to!! Lol
2000 Omega Elite 2.5 V6
MickAP
  • South Derbyshire
Re: Steering Idler
« Reply #37 on: 20 February 2010, 18:13:09 »
I've tried all this today with my Idler.
Let's just say I've had enough, and it's a second attempt tomorrow
F******** poxy thing :( :-[
Mick ;)
charlie
  • sunderland
Re: Steering Idler
« Reply #38 on: 20 February 2010, 18:24:51 »
Best of luck mick,I took the cowards way out in the end, :-[
MickAP
  • South Derbyshire
Re: Steering Idler
« Reply #39 on: 20 February 2010, 19:24:46 »
Yeah I may just do the same, after tomorrow.
And that comment I made was the cleaned up version. ;D ;D ;D ;D
Mick :D
« Last Edit: 20 February 2010, 19:25:05 by MickAP »
Omega 37
  • Northampton
    • CD 2.2, HP Firenza & TR6
Re: Steering Idler
« Reply #40 on: 20 February 2010, 19:33:47 »
I've given up too, going to the garage to get some heat onto the damm thing. Damm sausage gobbler's (germans) over engineer everthing. :D
MickAP
  • South Derbyshire
Re: Steering Idler
« Reply #41 on: 21 February 2010, 18:02:56 »
Mick :D
Hurray :D  Success I got it off :y
Found my long lost chisel and tw*tted it with that.
I first wedged another hammer head between a spare nut attached to the tapered bit and chassis member.
Then wacked hell out of it from underneath via the chisel with a lump hammer.....grrrr ;D
Simple job to replace with the new one, if only the old one was as simple to get off :-/
Car now feels better, and doesn't seem to pull to the left anymore.
Mick :y
« Last Edit: 21 February 2010, 18:08:02 by MickAP »
Omega 37
  • Northampton
Re: Steering Idler
« Reply #42 on: 21 February 2010, 18:44:26 »
Well done, did better than me! :y
Pages: 1 2 [3]  All   Go Up
