Pages: 1 [2] 3  All   Go Down
Author Topic: Service + timing belt @ 80,000 going to £500 +  (Read 7528 times)
Bent valve
Re: Service + timing belt @ 80,000 going to £500 +
« Reply #15 on: 31 May 2009, 07:08:35 »
Get the cam belt changed NOW mate! it must be changed every 40k miles or 4 years whichever comes sooner without fail!!!
Calm down .......  ;) how do you know that the car's not already had a cam belt change at 40k?  :y
If it did its still due one now...
 I think the 4 year replacement is a bit harsh though. I wouldnt replace the belt kit after 4years  if the car had only done say 15000 in that time
That would be your call and a poor one mate  :)[/quote]
Yes but i dont enjoy fitting cambelts as much as you! ;)
« Last Edit: 31 May 2009, 07:09:19 by Bent_Valve »
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #16 on: 31 May 2009, 08:33:41 »
Give me a shout then when you want yours doing  :y
« Reply #17 on: 31 May 2009, 10:21:52 »
depends what service your having, seems a little expensive, possibly 500pounds including vat maybe nearer the mark, parts I would have thought a max of 200-230 rest would be labour.
am really worried about the t belt going as it went on my last car and cost thousands. still seems a tad expensive to me, i was expecting a service to about £150 plus £100 for a timing change
300 is a fair price for timing kit change(belt tensioner and idler, tensioner being most important) from a garage imho. Plus fluids(oil and coolent usually) and filters(oil, air, fuel, and pollen)
Could easily run to 500 depending on their hourly rate. Does not seem too bad to me. Trouble is, more importantly, do they know what they're doing?
If you know someone who can do the cam belt and tensioner for 100 total bill. Then let me know...he can do mine.( 30k to go):-)
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #18 on: 31 May 2009, 15:14:55 »
I've just done mine at the four years interval and probably only 15,000miles. The belt was in mint condition considering but the tensioners were a little rough sounding and had a small amount of play. Worth doing for the immense peace of mind.
varche
« Reply #19 on: 31 May 2009, 18:56:53 »
Garbage, PM Sent ;)
3.2omegaestate
« Reply #20 on: 01 June 2009, 09:33:12 »
the really key thing here is not what the cost is but that the person that does the work knows exactly what they are doing and uses the right tools.  Many garages will say they can do the work but behind the scenes will botch it by not using the correct locking/timing tool.  Using this tool and using it accurately is an absoulute must.
I had my first belt change done at the dealer: they did a good job - no complaints BUT they were not spot on with cam 3,4.  When I did it, I really fettled the timing on 3,4 and it runs better
so don't focus so much on cost but on whether the garage knows what they are doing: ask to see their locking kit.  As them to explain the procedure for timing bank 1,2 to 3,4 - if they do not give a competant response - walk
I have just had my cambelt done by a friend/mechanic. Mine too was out on the timing, a tooth on the crankshaft pulley when camshafts were all aligned with their respective marks. It now pulls better, drops into overun (999.9 mpg displayed (I wish)) easier and gives better mpg!!!!
I used genuine parts, and included a water pump whilst at it. Lucky since the old one was leaking slightly and rough.
Two new cam covers and seals (old ones were suspect warped as breathers were clear)
plenum seals
6 plugs
cambelt kit
water pump
aux drive belt
oil filter
all came to a tad under £400 (inc discount). Thank fully I didn't have to pay for labour. A week later no6 coil went fut, £150 on two coil packs as well.
Get it done; properly. An extra bit of money spent on a quality job is worth it in the long run.   :y  :y
« Last Edit: 01 June 2009, 09:33:39 by 3.2omegaestate »
« Reply #21 on: 01 June 2009, 11:37:54 »
Really depends on what they call 'a service'. If its an oil change, then that is rediculously expensive.
garbage456
  • Carshalton, Surrey
« Reply #22 on: 01 June 2009, 16:35:39 »
thanks all, in PM contact with darth and pete
Vmax
  • Waterlooville, Hampshire.
  • Missing life on two wheels :(
« Reply #23 on: 01 June 2009, 16:40:42 »
Had my belt done locally for £165.. :P
Keep Calm And Carry On.......
Dazzler
  • Haverhill, Suffolk
« Reply #24 on: 01 June 2009, 17:01:51 »
If thats supply and fit, then you got yourself a bargin.
« Reply #25 on: 01 June 2009, 18:25:11 »
...... and tensioners?  :-/  :-/
garbage456
« Reply #26 on: 23 February 2010, 19:53:46 »
thanks guys, was it darth and pete, for doing my cambelt + service + finding the leaking oil from the gasket
Richard A
  • Aldridge, West Midlands
« Reply #27 on: 23 February 2010, 20:30:58 »
If your with 'Elite Pete' your Omega is in safe hands.
(could do with a weather proof garage) :y
Regards
Richard a
richard a
kev2b4
  • Luton, Beds
    • 2.5 CDX ,2.5 tourer
« Reply #28 on: 23 February 2010, 21:00:08 »
personally speaking , mine is due a cambelt soon on mileage ( overdue on time) - but I would prefer to take it to stoke or similar distance and get it done properly by someone who understands the beasties
Richard A
« Reply #29 on: 23 February 2010, 21:13:33 »
I very much agree, Pete & Loo Knee know there stuff, but get it done.  :y
Richard A
richard a
Pages: 1 [2] 3  All   Go Up
