Author Topic: Coolant bridge repair:  (Read 2228 times)
sandune
  • Essex Southend
    • 2.6 Omega Auto
« on: 27 February 2010, 08:40:24 »
Hi  i'm about to attempt to fix a leak at the coolant bridge.
    Can any one advise on which parts and codes before i visit vx ?
  Thanks sandune :( :'(
Re: Coolant bridge repair:
« Reply #1 on: 27 February 2010, 08:44:07 »
All here!  :y  :y http://www.omegaowners.com/forum/YaBB.pl?num=1211220529  :y  :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 27 February 2010, 08:44:44 »
 o rings, ptfe tape.  you could if you wanted change the coolent sensor and temp sender while your down there. :y o yes some plasters as your bound to cut your self. :D
Hoof'land storeman.
« Reply #3 on: 27 February 2010, 08:48:24 »
o rings,  ......
Dowty seals aren't they?  :-/
biggriffin
« Reply #4 on: 27 February 2010, 08:58:22 »
havnt done one for a while think they just copper. also doubt stealer will have them stock,local factors might.
Hoof'land storeman.
sandune
  • Essex Southend
    • 2.6 Omega Auto
« Reply #5 on: 27 February 2010, 09:10:33 »
Thanks Andy and biggriffin i'm off to the stealers i let
you know how i progress as this is a first for me.
 sandune
2woody
  • Northumberland
« Reply #6 on: 01 March 2010, 09:32:55 »
early ones copper - late ones Dowty
changeover unknown, at least by me anyway
« Reply #7 on: 01 March 2010, 12:56:25 »
must be very early - estate is early 98 and they were dowtys.  Stock item my stealer!
« Reply #8 on: 01 March 2010, 13:27:24 »
Never seen a V6 with copper washers on this part.....
« Reply #9 on: 01 March 2010, 13:29:18 »
Likewise, have always been doughty washers in my experience (and I've rebuilt a few '95 models too) :y
« Reply #10 on: 01 March 2010, 13:56:28 »
I have also done a few C25's off Cavs.....circa 94 era.
I am pretty sure that a copper washer would require additional clamping force to get a good quality water seal. Hence the dowty washers as they provide a seal via the rubber insert and a conductive path via the metal surround which ensures the temp sensor gets its 0V return path without over stressing the banjo bolt.
Page created in 0.031 seconds with 20 queries.
