Pages: 1 2 3 4 [5] 6   Go Down
Author Topic: Code 0300  (Read 9544 times)
Re: Code 0300
« Reply #60 on: 02 March 2010, 23:36:39 »
..... .. who the hell thinks Brackley is Bimingham !!!!  nearer Oxford !! .......
They're both in the Midlands ..... same difference to me!  ::)  ::)  ;)
Re: Code 0300
« Reply #61 on: 02 March 2010, 23:38:00 »
Never heard Oxford described as "Midlands" !!!!!
 :D :D :D :D :D
alunonhisown
Re: Code 0300
« Reply #62 on: 02 March 2010, 23:38:56 »
So TB it is then, will PM him tomorrow
Unless he wants to PM 1st and say when he can look at this pile of shit on my drive.
D.
Re: Code 0300
« Reply #63 on: 02 March 2010, 23:42:03 »
D.
Given the similarity of the distances/times .. I'd go for the first one who is available !!!!
Re: Code 0300
« Reply #64 on: 02 March 2010, 23:42:16 »
 :D :D :D :D :D
Depends where you live!  ;D  :y  :y
Re: Code 0300
« Reply #65 on: 02 March 2010, 23:43:58 »
 :D :D :D :D :D
Classed as South East  :y
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
Re: Code 0300
« Reply #66 on: 02 March 2010, 23:48:04 »
D.
'kin ell Di, since when is a 3.2 Omega Elite which has just had a major service and cambelt, done very cheaply by an Omega expert, with a very minor problem, a piece of shit??
Bet there are a few members on here who would happily swap their 'pieces of shit' with you love
Me first
Re: Code 0300
« Reply #67 on: 02 March 2010, 23:49:52 »
Me second....
Re: Code 0300
« Reply #68 on: 02 March 2010, 23:54:04 »
Diane,
You told me, that the car was "shaking" and running like a bag of nails and stank of unburnt fuel.
It was on this basis I advised against driving it, due to the fact that this sounded like a misfire symptom and I didn't want you to damage your cats.
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: Code 0300
« Reply #69 on: 03 March 2010, 00:05:52 »
D.
My sentiments too Nige!
If only I had a Tech2 of my own down here eh? (Food for thought?).
Re: Code 0300
« Reply #70 on: 03 March 2010, 00:09:00 »
D.
Shall we have a whip round for you ....  ??  I'll donate £1 ... only about £3999 to go !!!
http://cgi.ebay.co.uk/Tech-2-Master-Kit_W0QQitemZ280384808785QQcmdZViewItemQQptZUK_Diagnostic_Tools_Equipment?hash=item41483ca751
Re: Code 0300
« Reply #71 on: 03 March 2010, 00:09:04 »
Diane,
Well, this is new information, and it changes things.  :-?
For info, the emissions light on a DBW car will flash if the cats are believed to be in danger. Doesn't sound like it's in a state where it can be driven far.
Re: Code 0300
« Reply #72 on: 03 March 2010, 00:09:22 »
Also see The Boys Tech 2 sight, link at the bottom of one of his posts.
There are numerous causes of a random miss fire, trouble is non are showing a fault code to go with the 0300. Live data shows figures and outputs from engine sensors as the engine runs.
A for instance for you, my car has issues on hot days when starting, just cranks on the starter but wont fire, doesnt happen often for obvious reasons, so its nothing to worry about, but one theory was to check the air temp sensor built into the maf, this is used during the start up procedure as a referance before the maf (Mass Air Flow) sensor kicks in, or something like, the details are not important, but tech 2 shows this info real time.
My car didnt show ANY issues at all under live data, yet the symptoms pursist albeit very rarely. Its not necessary to hit the panic button at every issue or code that appears to point at trouble. If we did that nobody would ever buy a car at all. The Boy has a little mission when ever he tech 2's a car, he can always find "some" issue or other, and usually does. The cars history can almost be read to some extent, in fact his own car throws a gear box code of some sort and is concidered normal i believe. BMW e39 diesels throw a fuel pump code to do with fuel pressure as a matter of course, they run perfectly and you would never know the issue was there.
So i think its wise to take note of the issue as you have, and get it checked at a convenient time to you and your nearest admin with tech2, i guess that would be The Boy? And make the journey with an open mind ready to accept the fact that there may or may not be anything wrong at all. Chiiiiiil Winstaarn.
I suspect some owners would be delighted to only have that code after the pedal trick.
Edit, unless of course new info comes to light, i was writing this as James posted.
« Last Edit: 03 March 2010, 09:42:00 by chrisgixer »
Re: Code 0300
« Reply #73 on: 03 March 2010, 00:21:33 »
D.
He might prefer to look at the Omega Di ! (snigger)
« Last Edit: 03 March 2010, 00:22:29 by chrisgixer »
Re: Code 0300
« Reply #74 on: 03 March 2010, 09:38:34 »
Given the latest bit of info ... "shaking and stinking of fuel"  which is a tad different to the original "smells of fuel on startup" ... ....
may I ask the following ....
Does the smell of fuel come from the exhaust or under the bonnet  ??
Exhaust : unburned fuel, misfire probably caused by ignition problem, risk of damage to cats by petrol.
Underbonnet : Spilt fuel, leaking pipes/injectors, misfire probably caused by insufficient/incorrect fuel in cylinders. Serious risk of fire
Now, as I was the one who suggested a drive to a tech2 based on the original information I now suggest the opposite. do NOT drive the car until you KNOW where the problem lies.
It is difficult to long range diagnose at the best of times .. but when the information given is incomplete, or changes half way through, it becomes impossible.
If you want us to help ... at least give us the information we need in order to help !!
Wishful thinking and guesswork never fixes anything.
« Last Edit: 03 March 2010, 09:40:36 by entwood »
Pages: 1 2 3 4 [5] 6   Go Up
