Author Topic: Air con...  (Read 1090 times)
lou
  • Romford
  • Always expect the unexpected
Air con...
« on: 07 March 2010, 21:45:40 »
Is it normal for the aircon not work in this weather it was only 3 degrees this afternoon. the eco button still alters the revs, so I assume the compressor is working.
Bumbazor
  • Worksop
Re: Air con...
« Reply #1 on: 07 March 2010, 21:46:44 »
I'm not sure about the compressor being told to work or not but I've read a couple of posts which say the aircon doesn't get activated if the outside temp is less than 5...
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: Air con...
« Reply #2 on: 08 March 2010, 00:02:05 »
:y It's to protect the compressor.
