Author Topic: Facelift bumper bar and washer bottle  (Read 1554 times)
Bumbazor
  • Worksop
« on: 07 March 2010, 20:02:18 »
I have a mini-facelift car and have fitted a facelift MV6 bumper (did it ages ago). However, I have not yet got the facelift metal support. This is because I have a large washer bottle (windscreen and headlights) inside the current bumper support.
My question is; if I get a facelift bumper support, what implications would that have for my current washer bottle and neck? Would I have to get a washer bottle for the facelift support or could I use what I have now?
Thanks
Re: Facelift bumper bar and washer bottle
« Reply #1 on: 07 March 2010, 20:29:36 »
AFAIK washer bottles are same across the range I think the only physical difference is the addition of the pump for the headlight washers where without there is a bung
Bumbazor
  • Worksop
« Reply #2 on: 07 March 2010, 20:34:34 »
Ok so all I might have to do is modify the filler neck. That's not too bad
« Reply #3 on: 07 March 2010, 20:39:07 »
I understood that there were 2 different sizes. One for cars without headlight washers & another bigger bottle for those with.  :-/
« Last Edit: 07 March 2010, 20:41:09 by Andy_B »
Bumbazor
  • Worksop
« Reply #4 on: 07 March 2010, 20:40:00 »
... I have a large washer bottle (windscreen and headlights)...
Jim
  • Glasgow
    • Irmscher 3.2 V6 Elite
    • My Vauxhall Omega's
« Reply #5 on: 08 March 2010, 08:46:14 »
It should only be the filler neck you have to remove, as the pre-facelift has an extented neck to reach the slam panel.
Bumbazor
  • Worksop
« Reply #6 on: 08 March 2010, 09:17:32 »
Ok, thanks.
