Author Topic: light brown gunge in oil filler neck  (Read 4104 times)
Abiton
Re: light brown gunge in oil filler neck
« Reply #15 on: 10 March 2010, 12:50:57 »
How many miles has your engine done?
I'm reasonably sure that the amount of mayo generated will go up in proportion to engine wear (increased amount of blow-by gases) which will vary with mileage, quality of servicing and number of cold-starts.
The condensed moisture mostly comes from gaseous combustion products escaping downwards past piston rings, not some mysterious external source, IMHO. Yep, engines make water  ;).
« Last Edit: 10 March 2010, 18:40:17 by Abiton »
gixer14
  • leeds
« Reply #16 on: 10 March 2010, 16:25:38 »
normally occurs when breather pipes are blocked. give them a good blast out. should do the trick.
manny
  • bromorough.Wirral.
« Reply #17 on: 10 March 2010, 17:39:04 »
It forms in the filler neck as its a dead end so its a vapor trap. The v6 engine goes in vectra and that has no filler neck. Ive taken mine off.
2001 OMEGA MV6
Phil.d
  • lancashire
« Reply #18 on: 11 March 2010, 19:22:00 »
Ive got 126000 on the clock but spent a bob on oil cooler  , thermostat ,full pulley renewal and belts etc as wel as h/g.
Grrrrrr
  • Buckinghamshire
    • Jaguar. WTF have I done?
« Reply #19 on: 12 March 2010, 20:21:02 »
I've got it on my 2.6 too and used to get it on my old 2.5 too. No problems. Just keep the oil and breathers clear and you'll be fine.
Work is the curse of the drinking classes (Oscar Wilde)
