Author Topic: Lumpy running for 30-60 seconds  (Read 4026 times)
vic
  • Aldershot (Hampshire)
Re: Lumpy running for 30-60 seconds
« Reply #15 on: 11 March 2010, 18:24:17 »
Belay that last question new MAF ordered and on it's way......Watch this space he says with fingers crossed.
Thanks for the advice guys. :y
VC
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
« Reply #16 on: 11 March 2010, 18:35:53 »
Thanks Johnny, I was reading your posts the other day with interest about your MAF. Just nipped out onto the drive and quickly whipped off the MAF (getting quite quick with familiarity, it's been off and on so many times in the past couple of weeks.)  I have several No's on it; The maker is siemens and the body has the following Nos:
*5WK9 606
*90 530 463>PBT-GF30.
* bar code label 57959009.
I probably appear to be 'dense, ( I'm keen to learn so any advice is welcome) which of these do you think is the 'part No I need
I'm sorry, I don't know the part no for yours, I'm sure somebody on here will give it to you though, you can then search on ebay by typing that number into the search bar. I bought one from Vauxworld, and it appears to be working fine  :y
EDIT: Must type faster  ;D
« Last Edit: 11 March 2010, 18:36:23 by jmdavies »
vic
« Reply #17 on: 11 March 2010, 20:13:59 »
No worries Jonny, thanks mate! :y
vic
« Reply #18 on: 13 March 2010, 12:37:12 »
New MAF arrived this morning,....'Bish, Bash, Bosh, ten minutes later it's in and keeping my fingers crossed I turned the key [size=8](with her indoors in attendance)[/size] . Lumpy Running problem "Gone". A short twelve mile blast along the Blackwater Valley relief road, confirmed the misfire was "Gone". Still can't shake the feeling that this is too good to be true if you know what I mean. The MAF is definately and aftermarket jobbie (£33 new on Ebay albeit with a 12 month warranty) , so having due regard to the conventional wisdom of avoiding pattern parts I'll keep an eye on it. Even as the eternal optimist I'm hoping for the best and planning for the worst.
 Looking inside the MAF body it has the usual thermistor as per the original, but instead of 'two' platinum wires it has one wire, and in place of the second wire it has a resistor. The immediate upshot is the problems appear to be resolved.
Thanks for your advice guys, and Mr Wood it turns out your initial diagnosis was correct and youre batting average still intact, thanks mate! ;)
Sitting at my PC whislt waiting for the part to arrive I googled "diagnosing MAF problems video" Which I found educational. which may also be useful to other members of the forum :y
