Author Topic: Front wishbones on a 3.0 V6  (Read 1525 times)
Sixstring
  • Lydney, Gloucestershire
« on: 16 March 2010, 13:16:10 »
I have a bit of "knocking" whilst driving, and reckon it MIGHT be the front wishbones. Am told its a common thing, but how do you tell they are fubar???
Is there a "how to...."?
And whilst we are on the subject of "how-to's" is there one for changing the water pump on a V6 and the p.a.s. pump??
« Last Edit: 16 March 2010, 13:16:48 by Sixstring »
Welung666
Re: Front wishbones on a 3.0 V6
« Reply #1 on: 16 March 2010, 13:20:19 »
Wishbone check - Jack one side up onto an axle stand. Get a hefty screwdriver/small crowbar and try moving the wishbone in bothe front and rear mountings. You'll easily spot excess movement, they shouldn't travel more than 3 or 4mm if they are OK. Normally the rears that go first (vertical ones).
Radar
  • Berkshire
    • Elite 2.5 Auto
« Reply #2 on: 16 March 2010, 13:43:58 »
Forgive me if i'm being a numpty but aren't the fronts vertical and the rears horizontal?
« Reply #3 on: 16 March 2010, 13:47:52 »
There's a VERY good "how to" on changing them ...  I know ... I followed it !!
Nowt about checking them ... WIM told me mine were FUBAR .. they also checked the fitting - for free - when I took it back to have the geometry set after changing them ..
« Reply #4 on: 16 March 2010, 14:20:47 »
Also worth checking the anti roll bar drop links while you're there. :y
Welung666
« Reply #5 on: 16 March 2010, 14:23:23 »
No,the vertical ones are at the rear of the engine bay ;)
« Last Edit: 16 March 2010, 14:24:31 by Welung666 »
Radar
  • Berkshire
    • Elite 2.5 Auto
« Reply #6 on: 16 March 2010, 14:30:36 »
Thanks Lee, hope all is good! I think i must have got confused with polybushes or something.
2woody
  • Northumberland
« Reply #7 on: 16 March 2010, 14:41:16 »
Omega A ( i.e. Carlton ) was the opposite way round.
could be worth checking the damper strut too.
p.s. aftermarket wishbones last no time at all - best option is to put GM bushes in your old wishbone.
« Reply #8 on: 16 March 2010, 14:53:56 »
Or Meyle or Febi Bilstein
    • 530D M Sport, 330i Coupe
« Reply #9 on: 16 March 2010, 16:05:27 »
Try www.allgermanparts.co.uk as they can supply Lemforder wishbones for £62 a side with next day delivery.
Page created in 0.028 seconds with 20 queries.
