Author Topic: Small Water Loss ! Is it possible ?  (Read 2845 times)
Abiton
Re: Small Water Loss ! Is it possible ?
« Reply #15 on: 18 March 2010, 17:57:55 »
Doesn't appear to be any IN the sump..just ON the sump !
 :-[ Sorry, my misunderstanding.  Not having the best of days today.
Best of luck tracing the leak.  :y
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #16 on: 18 March 2010, 18:09:20 »
I had a similar problem for absolutely ages. In the end it is a problem with the heater matrix. Only found that out when I spotted water dripping from the a pipe above the auto gearbox. Proved it was within the car by dissing the heater matrix by inserting a short length of copper pipe in the heater cct matrix in and out pipes. Once you get the "quick release " connectors undone it is fairly easy to put a 4 inch bit of 15 mm copper plumbing pipe in. Mine has been running like that for a couple of weeks now while the replacement rad from Partsbuy arrives.
  • Auckland
    • Mazda MPV
« Reply #17 on: 18 March 2010, 18:21:29 »
On both my Omegas corrosion has eaten away at the outside of the coolant transfer pipe where the radiator top hose fits.
The resulting pitting means that the hose doesn't really seal properly & the position of the transfer pipe makes it difficult to inspect. :(
« Reply #18 on: 18 March 2010, 19:26:45 »
Had a look today... There seems to be a little evidence of a leak at the HBV so advised changing it whilst stripped down for cam covers.
Then keep an eye on it. Other possibility is that the new WP (recently fitted) isn't seated properly :-/ :-/
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #19 on: 19 March 2010, 00:17:23 »
Got the new HBV sitting on the back seat already...chap has put the job off till Tuesday
Hopefully once the top's off...he'll find the leak.
Not the end of the world though as long as its not dripping on to the dispack. THAT cost me a fortune with my previous mig.
